room lasers
fpajonk
Hi everyone,
did anyone of you come up with a nice way to generate room lasers like in this render?
SMART isolated.tif
SMART isolated.tif (5.99 MiB) Viewed 6449 times
Essentially, I need laser lines across walls and objects.
I'm placing an Octane light into a very tight pyramid but I'm not too happy with the results.
brasco
I do this using an ImageTexture in Distribution and scaling it very low on the Y axis using Projection:
Increasing the Beam Width user data (found on the Laser Crosshair Null) widens the beam (the multiplier is if you want it extra thin or fat):
The vertical one is just rotated in the Texture UVW transform but you can do it by rotating the Light itself.
brasco_Octane_Lasers_Projection_01.zip
cheers
brasc
Rig#1 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 7900K 4.7GHz | 64GB
Rig#2 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 3930K 4.4GHz | 32GB
Rig#3 Win 10 x64 | GTX 1070| GTX 1070| GTX 1070| i7 2600K 4.8GHz | 32GB
fpajonk
That looks fantastic. Would you mind sharing your scene file. I can't really get there. I tried using an image texture with two black bars and a slit in between but the result are odd.
brasco
fpajonk wrote:That looks fantastic. Would you mind sharing your scene file. I can't really get there. I tried using an image texture with two black bars and a slit in between but the result are odd.
I forgot to attach the file to the post - I've updated it and the link is at the bottom.
One extra thing to take into account is the size of the actual source - scaling it up and down is like focusing a projector, so for pin-sharp the source needs to be very small.
cheers
brasc
zoppo
I don't think I will ever need this, but it is definitely cool to check out that scene - thanks!
C4D 2025 | Win10
slepy8
same here, but you never know.
Thumb up for Brasco!
fpajonk
Ver cool, Brasco! TNX a lot!
dotcommer
Very cool! Adding it to my octane library of useful things!
Download my free Octane resources!
Paper Lantern | Fresh Snow (C4D Only) | Keyboard Displacement Texture | Solar Panel Texture
Mac Pro (2012) | 2x6Core 3.06GHz | 64GB | 1 x Titan Black 6GB
Portfolio: http://www.deltawavefx.com
nuno1980
New PPM (Progressive Photon Mapping) kernel will solve problems for the source of laser, of dot light... But only maybe new OR v4. :)
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
