Tips: TRUE specular materials and formulas for dispersion
nuno1980
Hello, guys. :D But this thread is REQUIRED!! Because most guys work to make any specular non-dispersive materials (water, glass, plastic...) for the lack of learning in Chemistry or Laboratory. :)
>>>>Using Octane Render, to get CORRECT (TRUE) specular settings due to the real life<<<<:
!VERY IMPORTANT!: All specular material should have the dispersion in the real life. ;)
NOTE: You choose any specular material -> refractiveindex.info (NOTICE: not any metallic nor other materials without transmission (T = 0 is invisible as non-refraction))
-- "Reflection":
it should be 1.000 - you don't reduce reflection because lower ior (index of refraction) reduces reflection except:
>>> especial materials - you can reduce "reflection" color and greysale - few examples
- glasses with purples reflection - https://newgradoptometry.com/wp-content/uploads/2014/07/crizal-prevencia-lens-dr-matt-geller.jpg ;
- filter integrated with purples reflection - https://img.clasf.co.za/2014/12/20/Price-Reduced-For-Quick-Sale-Philips-107E-CRT-Monitor-20141220204412.jpg ;
- anti-glare for glasses;
-- "Transmission" is 1.000 (greysale) for most specular materials - see "transmission (T = ...)" showed from refractiveindex.info
But if you want water or ice or any other to must be the absorption, look "medium" in "Transmission Properties" to add "absorption medium" node with checked "invert absorption" and to decrease the grayscale from 1.0 to 0.998 (water) or any lower.
Or if you want any "color" perferred to must be the absorption, look "medium" in "Transmission Properties" to add "absorption medium" node with checked "invert absorption" and to choose any color
-- "Index of refraction" and "Dispersion coefficient":
--> 3 formulas for dispersion (source web - https://en.wikipedia.org/wiki/Cauchy%27s_equation ):
!!NOTICE!! - Not "d line" as 0.58756 µm wavelength (n_d, V_d...) but YES "D line" as 0.58929 µm (n_D, V_D...) for be recommended. ;)
-- Abbe number's formula:
V_D = (n_D - 1) / (n_F - n_C)
V_D - abbe number
n_D - ior at 0.58929 µm
n_F - ior at 0.48613 µm
n_C - ior at 0.65627 µm
-- Conversion from abbe number (V_D) to dispersion coefficient (B):
B = (n_D - 1) / V_D * ((0.48613^2*0.65627^2)/(0.65627^2 - 0.48613^2))
B - dispersion coefficient
-- Conversion from original n_D to n_D_dispersed formula
A = n_D - B / 0.58929^2
--- A is n_D_dispersed
This conversion must enter "index of refraction" as n_D dispersion using Octane Render because you see the example of diamond material - 3 differences:
figure 1 - ior original w/o dispersion
figure 2 - ior original with dispersion -> incorrect because fig. 2 is different ior to fig. 1
figure 3 - ior dispersed (A) with dispersion -> correct because fig. 3 is as equal ior as fig. 1
Find n_D (ior at D line) and abbe number (V_D) of this material:
1- go refractiveindex.info and choose "3D - selected... artists" of "Shelf", "Crystals" of "Book" and "Diamond (C)" of "Page"
2- a) to get the number of n_D: digit "0.58929" (wavelength in µm) and click "enter" button (or press <enter> key)
b) to get n_F: digit again "0.48613" (wavelength) to enter
c) to get n_C: digit again "0.65627" (wavelength) to enter
Calculate 3 formulas of this material:
1- to get abbe number
V_D = (n_D - 1) / (n_F - n_C) = (2.4166 - 1) / (2.4305 - 2.4089) = 1.4166 / 0.0216
=> V_D = 65.58
2. to get dispersion coefficient
= 1.4166 / 65.58 *  ((0.48613^2*0.65627^2)/(0.65627^2 - 0.48613^2))
= 0.0216 * 0.523655 => B = 0.01131
3. to get A (= n_D_dispersed)
A = n_D - B / 0.58929^2 = 2.4166 - 0.01131 / 0.58929^2 => A = 2.3840
After calculation, on Octane Render enter in specular material settings:
- "index of refraction" - 2.384 (= A = n_D_dispersed)
- "dispersion coefficient" - 0.01131
If you are any worry with any noise colored, you can disable "dispersion coefficient" as 0.000 or you need to apply new AI denoiser in new OR v4 XB1. ;)
If you have any doubt, you can reply here. ;)
Fantastic rendering!! :D
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
paride4331
Hi nuno1980,
thank you very much for your post, it is very very interesting!
Regards
Paride
nuno1980
paride4331 wrote:Hi nuno1980,
Regards
Paride
Thank very much you too!! :D :D
@Admin or @moderator: I ask you pin to this thread because this thread is very important and guys find EASIER here. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
Happy holidays, guys! :)
I change link...
--> 3 formulas for dispersion (source web - http://www.luxrender.net/forum/viewtopic.php?p=84755 ):
and to:
Because luxrender's forum is "dead" - my user is lost (forum). ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
GXGsynth
It would be awesome if there was a list of truly accurate Octane IORs + dispersion coefficients for basic glass + gemstones, or at least a spreadsheet that would make it easy to enter the formulas for different materials, this math is really incredible but a bit over my head and a lot of work to do!
nuno1980
Watch below about learn "Silverwing Long Tip: Diamond Series: The Shading" and any other specular material but on "Cinema 4D" and NOT on Octane Render (OR) standalone. :)
NOTICE: The Abbe Number bar is NOT available under OR standalone or plugin without any 3rd party. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
Hello, guys. :)
Almost 3 years later, I updated OP to edit "transmission" (check bit below of this) and to add "absorption".
Best regards. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
