OctaneRender® 2026.2 for 3ds max® v26.6
paride4331
coilbook wrote: Fri Mar 27, 2026 5:21 pm Hi,
How do you adjust sampling rate for fire (light) using std volume medium?
Hi coilbook,
I’m not sure what you mean by "adjust sampling rate" in this panel.
coilbook
paride4331 wrote: Mon Mar 30, 2026 9:58 am
Hi coilbook,
Hi Paride,
Like all lights and emitters in octane have this but there is no sampling rate for fire light.
Also do you have any tutorials or samples how to use vectron to generate landscapes like grand canyon and using only procedural shaders. For some reason vectron displace for image textures cannot be found where image projection can be used .
Also how to convert any mesh to vectron mesh
Thank you!
coilbook
Octane Vectron is great but can we get easier UI and the way to use it?
coilbook
Octane still renders itoo preview proxy meshes as proxy meshes. Only itoo point cloud mode works
paride4331
coilbook wrote: Wed Apr 01, 2026 5:14 pm
Hi coilbook,
Hi Paride,
Thank you!
Hi coilbook,
Here for you. In any case, if you show me what you’re trying to achieve, I can try to help you.
vect_displ.zip
(147.2 KiB) Downloaded 52 times
paride4331
coilbook wrote: Sun Apr 05, 2026 5:20 am Octane still renders itoo preview proxy meshes as proxy meshes. Only itoo point cloud mode works
Hi coilbook,
could you share a scene with this issue?
paride4331
Hi coilbook,
Hi Paride,
Thank you!
Hi coilbook,
You can’t use a mesh directly in Vectron, you first need to convert it to an SDF, and then use the Vectron (Node) modifier from the Octane Vectron Operator menu.
coilbook
Anyway to have custom mesh shapes as real octane lights?
paride4331
coilbook wrote: Tue Apr 14, 2026 3:05 am Anyway to have custom mesh shapes as real octane lights?
Hi coilbook,
Why not apply an emitter material directly to the geometry?
remKa
Hello,
Blend Angle in the triplanar map has no effect when using a single texture , please see attached file.
Im using texture displacement set as "high"
Enregistrement de l'écran 2026-04-16 115438.mp4
(3.84 MiB) Downloaded 52 times
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
Return to “Releases”
