OctaneRender™ 2021.1 XB1
karl
PolderAnimation wrote:Thanks team! Looking forward to testing this! Thanks!
I have a question about highlight compression in the imager. What is the exact math Octane uses for this? Because this would be extremely helpful for a good 16/32 bit workflow. Then we can render it without highlight compression but view it with. And then in our composting software we can apply it after we have done our tweaks there (and still have the full 16/32 bit range).
Do you specifically want to match exactly what Octane does, or do you just want to apply some nice-looking tone curve? The easiest thing would be to use OCIO (for example, the sRGB view in the ACES 1.2 config) in your compositing software - you'd probably end up with nicer highlight compression too since those configs tend to have a lot of color science research baked in to them.
joenyc
abstrax wrote:
joenyc wrote:Does this include the new PPM kernel?
No it doesn't as you can see in the release notes.
I figured, I was just asking since I didn't see it in the release notes, but it was just mentioned as coming in the GDC talk. What's the timeline for the new kernel?
Mac Pro (2019), 2.7 GHz 24-Core, 384GB RAM, AMD Radeon Pro W5700X | Houdini
abstrax
joenyc wrote:I figured, I was just asking since I didn't see it in the release notes, but it was just mentioned as coming in the GDC talk. What's the timeline for the new kernel?
Currently it's part of the next development cycle, which just started internally. That's all I can say right now with any degree of confidence. Sorry.
nuno1980
ok. Does new kernel support Maxwell (GeForce 900 series) card?
NOTE: I'm sorry for bad english due to mute ;)
i7-12700KF
2x16GB RAM@DDR4-3600
MSI PRO Z690-A DDR4
Zotac GF RTX 4090 <3 :mrgreen:
SSDs OCZ RD400 0.5TB and Crucial 2TB SATA3
HDD 1TB SATA2
LG BD-RE BH16NS40
PSU 1kW
CRT 19" Samtron 19" :|
PolderAnimation
Thanks yes we are planning this, but for now it would help if we would know the highlight compression math octane uses. Thanks.
Win 10 64bit | RTX 3090 | i9 7960X | 64GB
J.C
Thanks Otoy! So many goodies ;)
System – Windows 11
Kalua
Great release! Looking forward to try these goodies!
Regards,
C4D 2025.1.1 Octane 2025.2.1 v1.5.1, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 552.22
andrey.krivulya
Wow! Thank you! Awesome release! Congrats for everyone!
win 10 /64x Intel Core i9-11980HK - 64Gb RAM - 3080 Laptop - 16Gb VRAM - AERO 15 OLED YD
My youtube channel with 3d tutorials ----- >>>> https://www.youtube.com/c/AndrewKrivulya
pegot
Clipping: Specular artifacts appear when using the Direct Light kernel.
When using Direct Light kernel there appears some issue where objects used for clipping show some kind of shadow outline of their original shape on the clipped object's material. Please refer to attached sample renders.
The cube has a default Universal material. The top side is clipped with a cone. The front side is clipped with a sphere. You can see part of those shapes reflected on the cube's material.
It doesn’t seem to be a shadow of those objects as they still appear even when the cube's object layer has shadow visibility toggled off.
Instead, this seems to be a specular artifact. Turning specularity to 0 removes these artifacts (but changes the look of the cube's material of course).
One way to remove these artifacts and still keep the cube's specular setting intact is by using a white transmission color and setting transmission type to Diffuse.
NOTE that these artifacts do not seem to appear when using the PMC or Path Tracing kernels.
Win 10
3.7Ghz i9 10900k / 64GB
ASUS STRIX Z490-E
PSU: PowerSpec 850Wd
RTX 3090 Asus Tuff
Network rendering:
Win 10
4.2Ghz i7 7700k / 64GB
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 Ti EVGA Hybrid
RTX 3080 ASUS Tuff
GTX 1080ti SC Black (wc)
Kalua
pegot wrote:Clipping: Specular artifacts appear when using the Direct Light kernel.
Have you tried to increase diffuse/specular depth?
