Do you specifically want to match exactly what Octane does, or do you just want to apply some nice-looking tone curve? The easiest thing would be to use OCIO (for example, the sRGB view in the ACES 1.2 config) in your compositing software - you'd probably end up with nicer highlight compression too since those configs tend to have a lot of color science research baked in to them.PolderAnimation wrote:Thanks team! Looking forward to testing this! Thanks!
I have a question about highlight compression in the imager. What is the exact math Octane uses for this? Because this would be extremely helpful for a good 16/32 bit workflow. Then we can render it without highlight compression but view it with. And then in our composting software we can apply it after we have done our tweaks there (and still have the full 16/32 bit range).
OctaneRender™ 2021.1 XB1
I figured, I was just asking since I didn't see it in the release notes, but it was just mentioned as coming in the GDC talk. What's the timeline for the new kernel?abstrax wrote:No it doesn't as you can see in the release notes.joenyc wrote:Does this include the new PPM kernel?
Mac Pro (2019), 2.7 GHz 24-Core, 384GB RAM, AMD Radeon Pro W5700X | Houdini
Currently it's part of the next development cycle, which just started internally. That's all I can say right now with any degree of confidence. Sorry.joenyc wrote:I figured, I was just asking since I didn't see it in the release notes, but it was just mentioned as coming in the GDC talk. What's the timeline for the new kernel?
ok. Does new kernel support Maxwell (GeForce 900 series) card?abstrax wrote:No it doesn't as you can see in the release notes.joenyc wrote:Does this include the new PPM kernel?
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
NEW ViewSonic XG2431 24"
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
- PolderAnimation
- Contact:
Thanks yes we are planning this, but for now it would help if we would know the highlight compression math octane uses. Thanks.karu wrote:Do you specifically want to match exactly what Octane does, or do you just want to apply some nice-looking tone curve? The easiest thing would be to use OCIO (for example, the sRGB view in the ACES 1.2 config) in your compositing software - you'd probably end up with nicer highlight compression too since those configs tend to have a lot of color science research baked in to them.PolderAnimation wrote:Thanks team! Looking forward to testing this! Thanks!
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
Thanks Otoy! So many goodies
System – Windows 11
System – Windows 11
Great release! Looking forward to try these goodies!
Regards,
Regards,
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
- andrey.krivulya
- Contact:
Wow! Thank you! Awesome release! Congrats for everyone!
Windows 11 Pro / Intel Core Ultra 9 285HX / 96GB DDR5 / RTX 5090 Laptop 24GB / 4TB SSD / MSI Titan 18 HX AI
My youtube channel with 3d tutorials ----- >>>> https://www.youtube.com/c/AndrewKrivulya
Clipping: Specular artifacts appear when using the Direct Light kernel.
When using Direct Light kernel there appears some issue where objects used for clipping show some kind of shadow outline of their original shape on the clipped object's material. Please refer to attached sample renders.
The cube has a default Universal material. The top side is clipped with a cone. The front side is clipped with a sphere. You can see part of those shapes reflected on the cube's material.
It doesn’t seem to be a shadow of those objects as they still appear even when the cube's object layer has shadow visibility toggled off.
Instead, this seems to be a specular artifact. Turning specularity to 0 removes these artifacts (but changes the look of the cube's material of course).
One way to remove these artifacts and still keep the cube's specular setting intact is by using a white transmission color and setting transmission type to Diffuse.
NOTE that these artifacts do not seem to appear when using the PMC or Path Tracing kernels.
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
Have you tried to increase diffuse/specular depth?pegot wrote:Clipping: Specular artifacts appear when using the Direct Light kernel.
