Weird Halos
treddie
Hey everybody.
Has anyone encountered this before. These weird halos that seem not right. Or maybe they ARE rendering correctly, but just seem odd to me:
Octane 3.04 (a tad old, I know).
Win7 | Geforce TitanX w/ 12Gb | Geforce GTX-560 w/ 2Gb | 6-Core 3.5GHz | 32Gb | Cinema4D w RipTide Importer and OctaneExporter Plugs.
nuno1980
If you use PT or PMC kernel then seems to be caustics. :)
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
treddie
But there are no refractive objects in the scene.
Hi treddie,
what about the specular value of the glossy material?
I suspect that the rounding is causing the effect of caustics at borders :roll:
ciao beppe
Zay
Could be wrong vertex normals smoothing. You can fix this by adding it manually under "Object Smoothing".
Don't check "Load vertex normals". Set "Max Smoothing Angle" to 80 or lower and then load the object again and see if it hasn't fixed the problem.
nuno1980
treddie wrote:But there are no refractive objects in the scene.
Ok.
But... "In optics, a caustic or caustic network is the envelope of light rays reflected or refracted by a curved surface or object, or the projection of that envelope of rays on another surface." - see https://en.wikipedia.org/wiki/Caustic_(optics) about "caustics" :)
Caustics at PT
i7-12700KF
32GB DDR4@3600
treddie
Sorry for the delay in getting back. I have been slammed with work, but will report back once i try out everyone's suggestions.
