Weird Halos
treddie
Hey everybody.
Has anyone encountered this before. These weird halos that seem not right. Or maybe they ARE rendering correctly, but just seem odd to me:
Octane 3.04 (a tad old, I know).
Win7 | Geforce TitanX w/ 12Gb | Geforce GTX-560 w/ 2Gb | 6-Core 3.5GHz | 32Gb | Cinema4D w RipTide Importer and OctaneExporter Plugs.
nuno1980
If you use PT or PMC kernel then seems to be caustics. :)
NOTE: I'm sorry for bad english due to mute ;)
i7-12700KF
2x16GB RAM@DDR4-3600
MSI PRO Z690-A DDR4
Zotac GF RTX 4090 <3 :mrgreen:
SSDs OCZ RD400 0.5TB and Crucial 2TB SATA3
HDD 1TB SATA2
LG BD-RE BH16NS40
PSU 1kW
NEW ViewSonic XG2431 24" :D
treddie
But there are no refractive objects in the scene.
Hi treddie,
what about the specular value of the glossy material?
I suspect that the rounding is causing the effect of caustics at borders :roll:
ciao beppe
Zay
Could be wrong vertex normals smoothing. You can fix this by adding it manually under "Object Smoothing".
Don't check "Load vertex normals". Set "Max Smoothing Angle" to 80 or lower and then load the object again and see if it hasn't fixed the problem.
nuno1980
treddie wrote:But there are no refractive objects in the scene.
Ok.
But... "In optics, a caustic or caustic network is the envelope of light rays reflected or refracted by a curved surface or object, or the projection of that envelope of rays on another surface." - see https://en.wikipedia.org/wiki/Caustic_(optics) about "caustics" :)
i7-12700KF
MSI PRO Z690-A DDR4
HDD 1TB SATA2
LG BD-RE BH16NS40
PSU 1kW
treddie
Sorry for the delay in getting back. I have been slammed with work, but will report back once i try out everyone's suggestions.
