Render caustics cleaned at PMC - s/px & sun sizes
Forums: Render caustics cleaned at PMC - s/px & sun sizes
Postby nuno1980 » Wed Dec 16, 2015 12:00 pm
nuno1980 Wed Dec 16, 2015 12:00 pm
Hello, guys! :) But this thread is very important!
Render caustics are (almost) cleaned:
Sun sizes / resolutions screen - 1002x602 .... / 1920x1080 . / 3840x2160
0.1x (on Saturn)........................... - 13,500k spp* / 4,000k spp* / 1,000k spp*
1x (on Earth)................................ - 260k** .......... / 75.5k ........... / 18.9k
2x.................................................. - 78k ................ / 23k ............... / 5.75k
4x ................................................. - 23k ................ / 6.8k .............. / 1.7k
8x ................................................. - 7k .................. / 2.1k .............. / 525
10x ............................................... - 4.9k ............... / 1.45k ............ / 360
"spp" - samples per pixel
VERY IMPORTANT: do not forget to disable "caustic blur" from default at PMC settings. If we set to 10k-reject to may get some noises (noises colored if any specular material has dispersion) then we try more spp.
* - we can't increase "Max. samples" from 256k using OR 2.24.2 :( But IMPORTANT!!! - we'll change "Max. samples" from default as 500 to 0 to get infinite spp using newer version of OR.
Do you like this thread? :D
If you want any other planet then contact me. ;)
NOTE: I'm sorry for bad english due to mute ;)
[email protected]
16GB [email protected]
ASUS Z97-Pro Gamer
EVGA GF GTX 980 Ti SC+ 2.0 :D
SSD OCZ RD400 0.5TB
HDDs 1TB SATA2 and 3TB SATA3.
LG BD-RE BH16NS40
PSU 1 kW
LCD-LED monitor 24" BenQ XL2411P NEW! :D
nuno1980
Re: Render caustics cleaned at PMC - s/px & sun sizes
Postby nuno1980 » Mon Dec 28, 2015 12:42 pm
nuno1980 Mon Dec 28, 2015 12:42 pm
I investigated caustics... but I would need to increase from 23 kS/px to 50 kS/px at sun size 4x because this increase of S/px reduces noises colored for other things (not caustics). ;)
Sun size 4x at 25 kS/px
This image has to seem few noises colored. ;)
Sun size 1x at 256 kS/px
This image is cleaned and looks pretty well! :D
PMC settings:
27-depth both diff+spec
10k-reject
parallelism 1
"Ice" material:
reflection 0.930
transmission 1.000
ior 1.299
coefficient dispersion 0.003
--> Do you like that? :)
[email protected]
ASUS Z97-Pro Gamer
SSD OCZ RD400 0.5TB
LG BD-RE BH16NS40
PSU 1 kW
nuno1980
Postby Elvissuperstar007 » Tue Dec 29, 2015 11:26 am
Elvissuperstar007 Tue Dec 29, 2015 11:26 am
ice in the material necessary to tick the fake shadows
win 7 /64x C2Quad 6600 2.4/ Nvidia 9800 GX2 1gb 512 bit + Asus 480 GTX/ DDR2 8Gb / NVIDIA 460 GTX 2GB/2x NVIDIA 580 GTX 3GB
Elvissuperstar007
Postby nuno1980 » Tue Dec 29, 2015 11:48 am
nuno1980 Tue Dec 29, 2015 11:48 am
Elvissuperstar007 wrote:ice in the material necessary to tick the fake shadows
I do never like fake shadows as fake caustics because it looks BAD caustics rendered = no "real-life" and I deserve much "real-life". lool
But I wait new kernel as maybe progressive photon mapping (PPM) for much shorter time render than PMC. :)
[email protected]
ASUS Z97-Pro Gamer
SSD OCZ RD400 0.5TB
LG BD-RE BH16NS40
PSU 1 kW
nuno1980
Postby djart » Wed Dec 30, 2015 1:50 pm
djart Wed Dec 30, 2015 1:50 pm
Whats lool? "Laughing out out loud"...
But anyway, you do a very good job by giving unnecassery information to the community :)
djart
Postby nuno1980 » Wed Dec 30, 2015 2:34 pm
nuno1980 Wed Dec 30, 2015 2:34 pm
djart wrote:Whats lool? "Laughing out out loud"...
yeah. ;) But "lol" - looool, lolol or lloll...
[email protected]
ASUS Z97-Pro Gamer
SSD OCZ RD400 0.5TB
LG BD-RE BH16NS40
PSU 1 kW
nuno1980
Postby nuno1980 » Thu Mar 24, 2016 10:21 pm
nuno1980 Thu Mar 24, 2016 10:21 pm
See differences of caustics between 3 images at S/px and resolution screen about teaport:
- at 360x216 - 150 kS/px
- at 1002x602 - ~19,337 S/px
360x216 and 1002x602 seem to be same caustics and same noises.
- at same resolution screen - 150 kS/px
Higher resolution screen = better caustics and less noises at 150 kS/px :) but longer render time. ;)
I'll buy OR in my anniversary (on july) but maybe few next months. :)
--> Do you like this? - but IMPORTANT!! Should respond me it. ;)
[email protected]
ASUS Z97-Pro Gamer
SSD OCZ RD400 0.5TB
LG BD-RE BH16NS40
PSU 1 kW
nuno1980
Postby bepeg4d » Fri Mar 25, 2016 8:42 am
bepeg4d Fri Mar 25, 2016 8:42 am
Good tests nuno, have you tried by rendering at double or quad for few samples and then down scaling at the original resolution?
ciao beppe
Postby gabrielefx » Fri Mar 25, 2016 9:11 am
gabrielefx Fri Mar 25, 2016 9:11 am
teapot test is not ok,
when you involve many objects in interior spaces you will need 8 Titan X to get a clean image.
Fox exteriors PMC is useless, pt is a lot faster especially if you set GI clamp to 1. Also using PT with GI set to 1 you have to use caustic blur if you have metallic or very reflective objects in the scene.
For interiors you can use pmc but you need 8 fast gpus, it's better to use pt, Octane will generate sharper images, well defined texture and less noise in dark areas.
I never used glossy and specular samples at high values except you have several glass layers, I always use 8-16, rarely 24.
Caustics are useful only if you create a pool.
Don't use dispersion because it generates noise.
regards
gabrielefx
Postby nuno1980 » Fri Mar 25, 2016 12:44 pm
nuno1980 Fri Mar 25, 2016 12:44 pm
bepeg4d wrote:Good tests nuno, have you tried by rendering at double or quad for few samples and then down scaling at the original resolution?
ciao beppe
No, 3 images are original. But I'll downscale to 1280x800 (eg) for blur by AA noises from 2560x1600 (eg) after OR bought. :)
For downscale, open any PNG image with Paint, zoom out from 100% to 33% or 50% to lower resolution screen and capture (press keys ctrl+print) it. Run 2nd Paint program to paste this image captured and cut from it to image rendered. ;)
gabrielefx wrote:teapot test is not ok,
regards
My test is good!! :evil:
Your tips about 8 GPU's is good but I haven't very big ("professional") money. But I'll upgrade to new GeForce x80 Titan (Pascal) in Christmas and Pascal with HBM2 will be ~10x faster than Maxwell at GPU computing only. :D After X80 Titan released, we'll review surprise and very good result using OR. :)
Do you deserve "real-life"? If you respond me "yes" then should correct render and specular material settings:
- PMC kernel with:
24-depth (diff+glossy) for 1 clear glass only or between 100- and 300-depth for many clear glasses and/or few mirrors or for 1 3D star glass;
paralellism 1;
no caustic blur;
max GI;
5k or 10k reject.
- specular material with:
reflection between 0.9 and 0.98;
correct index of refraction* if it has dipsersion then should reduce índex dispersed as índex original from index original;
must enable dispersion with correct value*
* - see https://refractiveindex.info/ and do formulas**
** - formulas:
B = (n_d - 1)/V_d*((0.48613^2*0.65627^2)/(0.65627^2 - 0.48613^2))
F and C = F and C wavelengthes - If wavelength = 589.3 nm then should use F = 486.13 nm and C = 656.27 nm
n_d_dispersed = n_d_original - 10/3*B
B -> dispersion coefficient
n_d -> refractive index
V_d -> abbe number
n_d_dispersed - refractive index dispersed if the dispersion is enabled, for Octane Render software only
If you have any doubt about formulas, contact me. ;)
You may not learn abbe number/dispersion because you haven't Chemical and/or Laboratory required. :P
[email protected]
ASUS Z97-Pro Gamer
SSD OCZ RD400 0.5TB
LG BD-RE BH16NS40
PSU 1 kW
nuno1980
Next
Return to Works In Progress
Users browsing this forum: No registered users and 5 guests
Wed Jul 08, 2020 2:26 am [ UTC ]
