Render passes reflection and shadows not working
Micha3D
I use the direct lighting kernel, but also at the other kernels this passes are empty. Any idea what is wrong?
Ciao,
Micha
Win7 64 | Dual Xeon E5-2687W | GTX 1080ti 11GB + GTX 780 6GB | Rhino3D
Sorry Micha - I do not understand your question.
stratified
A necessary pre-condition for shadows and reflection passes to work is setting up some render layers. Have a look at this section of the manual.
cheers,
Thomas
You also need Kernel->Alpha Channel enabled to get the shadow pass.
Micha3D
... doesn't work here. See my screenshots, the big part is metallic at the beauty pass.
May I suggest having a read of viewtopic.php?f=51&t=44350 and viewtopic.php?f=51&t=44267. If you are doing shadow passes, you will need to assign part of the geometry in the scene to a different layer - and for that you need a version of the OctaneRender for Rhino plugin which is later than the demo version. This feature has only recently been added.
nuno1980
Should use path-tracing or PMC kernel.
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
Micha3D
Wow, that's complex for a beginner. At Vray I enable the output channels I need and than they are rendered. Looks like Octane can do more, but there is no easy one-click solution. :?
