I use the direct lighting kernel, but also at the other kernels this passes are empty. Any idea what is wrong?
Ciao,
Micha
Render passes reflection and shadows not working
Sorry Micha - I do not understand your question.I use the direct lighting kernel, but also at the other kernels this passes are empty. Any idea what is wrong?
- stratified
A necessary pre-condition for shadows and reflection passes to work is setting up some render layers. Have a look at this section of the manual.
cheers,
Thomas
cheers,
Thomas
You also need Kernel->Alpha Channel enabled to get the shadow pass.
May I suggest having a read of viewtopic.php?f=51&t=44350 and viewtopic.php?f=51&t=44267. If you are doing shadow passes, you will need to assign part of the geometry in the scene to a different layer - and for that you need a version of the OctaneRender for Rhino plugin which is later than the demo version. This feature has only recently been added.... doesn't work here. See my screenshots, the big part is metallic at the beauty pass.
Should use path-tracing or PMC kernel.
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
NEW ACER Predator XB273U F5 27"
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
Wow, that's complex for a beginner. At Vray I enable the output channels I need and than they are rendered. Looks like Octane can do more, but there is no easy one-click solution.
Win7 64 | Dual Xeon E5-2687W | GTX 1080ti 11GB + GTX 780 6GB | Rhino3D
