House in Porugal 10hours Job
resmas
Hello all.
Its been a long time since i share some work, but is time to show what i have been doing with Octane inside Sketchup.
The plugin is great and still in Beta stage with many features in the roadmap...but is just amazing to join Octane with the simplicity of Sketchup. ;)
As an architect I'm not the best 3D artist, but i do my best to turn ideas into 3D...Octane is amazing.
This was made in 1 work day... so render times in 1080p were made in 5 to 10 minutes max.
Cheers to all.
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
nuno1980
Porugal!??!?!? Bad but yes Portugal.
Lights are too bright - should reduce much intensity or off lights, if sunlight.
Your images #8 and #9 -- Should change kernel to PMC at ~15k-sample without "caustics blur" because look the gate has glass (reflected) for appear caustics in the stone floor.
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
mark0spasic
Nice work in short time frame ;)
Could you tell us more about settings you used?
AMD FX 6300, 24 GB RAM, Gigabyte ga-990fxa-ud5, 2x MSI GTX 780 3GB
resmas
mark0spasic wrote:Nice work in short time frame ;)
Thanks mate
I'm not at my workstation now, but i will post later some details.
Most of the renders were in DL diffuse, and AO. Depending on the result i wanted.
In short time like this project, PT and PMC is not an option. In SU plugin we are using Octane 2.06.... So coerente mode is not na option and GI clamp in PT is not available.
When i need better results i export. to StandAlone to use the new 2.20 features.
Cheers
Resmas
smicha
For such a short time it's a great job. This is important when a client is urging you...
With 2.21.1 and PT and some settings tweak (GI clamp, coher., path term. pow.,..) you'd also score fast results.
jbsfender
I like it! Grass material looks awesome! Would you mind sharing this?
Many thanks.
nuno1980
Please should read my message (yesterday)! I'm required that you change to PMC (no "caustic blur") because your both videocards are very fast.
Caustics at PT
i7-12700KF
32GB DDR4@3600
resmas
smicha wrote:For such a short time it's a great job. This is important when a client is urging you...
Yes that was a tight time window to work. Was decided one day at night, started working 8am, and showed to client at 6pm... :shock:
Haha :D ...but this kind of works are interesting to do, there is no time to think...its just work..work. Sometimes we need this to break our limits and realize what we can do in a short time.
Octane is a great tool to show projects to clients. Especially if you are an architect...sun/sky system is great. Almost Heaven...when we get Clouds will be even better.
Octane 2.21.1 is really good...the speed imrovements are stuning, but as you know our SU plugin was not updated...we need our Fuzzy back. :evil:
jbsfender wrote:I like it! Grass material looks awesome! Would you mind sharing this?
Many thanks.
Thank you mate, there is no secret to this grass, its "just" displacement and different texture as diffuse. Depending on the size of the lawn, you need to tweak to the desired effect. In Close shoots it looks good, but in distant or aerial views you need a good texture to diffuse (seamless one).
I don't know where I got them from, but most of my textures are edited to my needs.
I have uploaded the ones I used in this grass, but you can see that different shoots have different grass.
nuno1980 wrote:Please should read my message (yesterday)! I'm required that you change to PMC (no "caustic blur") because your both videocards are very fast.
Nuno, most of your comments in other people work are...how can I say this?...empty of any point!
You are not saying anything that have any constructive critic...you are just saying the obvious. Of course PT and PMC are better but in many works there is no need to use them. The person that choose what Kernel to use is the person who design the image.
There is a reason for every kernel in Octane System...ones are faster and not so realistic, others are slower and more real.
There no point on keep saying "the image you should use PMC...bla bla bla...then...you should use PMC".
Thank you for the critic about the lights are a bit over bright, but was a request of the client. ;)
Cheers to all
resmas
nuno1980
resmas wrote:Nuno, most of your comments in other people work are...how can I say this?...empty of any point!
resmas
Yeah! ;) But...
See my image about lack of caustics - Therefore, should use PMC with ~15k-sample but don't forget to disable "caustic blur".
Somos portugueses e também moro em Portugal! :D
Caustics at PT
i7-12700KF
32GB DDR4@3600
SusanEH
look so realistic and smooth :)
