Smooth & Easy Camera Animation for OR Standalone, ORC v1.21
jitendra
I have been looking for such script from very long.
Thank you so much "Mithrandir" for making and sharing this amazing script.
Best Regards, Jitendra
whersmy
It still crashes for me....what version of octane and ORC`cam are you using jtendra?
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
jitendra
whersmy wrote:It still crashes for me....what version of octane and ORC`cam are you using jtendra?
I am using OctaneRender 2.20. And OlReadyCam_v1_21.zip.
jitendra
Is it possible to create the animation frames for multi-passes (For example, Reflectiona and Refraction Channels? If yes, how? Thanks.
Interfaces
it does not work, should execute the file ffmepg.exe
can you give me your way for all the file. (c / program / ......)
thank you (version 2.20 and ORC v1.21)
jitendra
Interfaces wrote:it does not work, should execute the file ffmepg.exe
Hey, I didn't tried the ffmepg.exe, this is because, I usually create movie file in other program.
Interfaces
hi, I do not get to run the script, I found by chance. I use a server (I :) for all file.
the script does not work on server it runs on (C :) only.
I'm glad it works,
would be possible to:
- Add keyboard shortcuts.
- Add del key frame buttons
- To have scripting with the server (I :) or other letters
THANKS
Refracty
How can I delete keyframes?
ssouth
Hi all, I'm trying to use Octane 1.50 with ORC 1.21
getting this error:
The script crashes when I press [Alt] + [R] to run ORC
Any thoughts?
Steve
ssouth
Ok, was able to finally sit down and look at the code... and fixed (at least to my satisfaction) the issue I was having. Seems the render call was defaulting to 4000 samples/pixel but was being told to do just one/pixel...
so I added a couple lines to the code to set the sample/pixel variable.
Here render.lua:
 373       octane.render.start
 374       {
 375           renderTargetNode = self.targetNode,
 376           maxSamples       = samples,            -- added this line
 377           callback         = self.callback,
 378       }
and here keyframe.lua:
754    octane.render.start
755    {
756        renderTargetNode = Render.targetNode,
757        maxSamples       = keyframe.samples.slider.value,  -- added this line
758        callback         = Render.callback
759    }
Return to “Lua Scripting”
