Mix Displacement node for OctaneRender for Blender (2026.2 - Addon version)
linograndiotoy
Hi everyone,
I’ve created a custom Mix Texture Displacement Group Node for OctaneRender for Blender (2026.2 – addon version), designed to simplify the process of mixing multiple Texture Displacement nodes.
While this can be achieved using standard shading nodes, the setup can quickly become complex and harder to manage.
This node allows you to achieve the same result in a more controlled and streamlined way.
Same result. Fewer nodes.
The project file is included in this post and contains:
  • the Mix Displacement Node
  • a working example demonstrating how it can be used
I’ve also created a video showing both the manual workflow and the simplified version using the group node:
👉 https://youtu.be/Z1RQQs85umw
Feedback is welcome 👍
Octane_Mix_Disp_Node_Group_Lino_Grandi.blend
(134.15 KiB) Downloaded 181 times
p3taotoy
excuse me for posting here
I have tried installing the add on in 5.01 and 5.1
I keep getting add on install errors
any ideas
thanks
here is one from 5.1
Python: Traceback (most recent call last):
File "C:\Program Files\Blender Foundation\Blender 5.1\5.1\scripts\addons_core\bl_pkg\bl_extension_ops.py", line 1504, in execute
cmd_batch = self.exec_command_iter(is_modal)
File "C:\Program Files\Blender Foundation\Blender 5.1\5.1\scripts\addons_core\bl_pkg\bl_extension_ops.py", line 2598, in exec_command_iter
self.exec_legacy(source_filepath)
File "C:\Program Files\Blender Foundation\Blender 5.1\5.1\scripts\addons_core\bl_pkg\bl_extension_ops.py", line 2731, in exec_legacy
bpy.types.PREFERENCES_OT_addon_install.execute(self, bpy.context)
File "C:\Program Files\Blender Foundation\Blender 5.1\5.1\scripts\startup\bl_operators\userpref.py", line 830, in execute
bpy.ops.preferences.addon_enable(module=mod.__name__)
RuntimeError: Error: DLL load failed while importing octane_blender: The specified module could not be found.
nuno1980
p3taotoy wrote: Fri Apr 03, 2026 5:34 pmhere is one from 5.1
Good day. :) But Lino doesn't add any OR version support for Blender 5.1. Not Blender 5.x but yes "5.01" only.
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
p3taotoy
Many thanks
I'll post under general and see if I can get a fix aye.
Appreciate you replying
Peter
Return to “Blender”
