OctaneRender® 2025.2.1
mojave
Hi all,
We are happy to bring you OctaneRender 2025.2.1. This new version brings a few minor fixes. Thanks again to all those who sent us feedback and continuously help us to improve Octane.
In addition to that we are releasing a new OctaneBench 2025.2.1 with this version, which download links and assets are provided below. This new version comes with support for the latest hardware and uses the same test scenes as the previous version with only some minor changes.
Important notes:
  • The minimum NVIDIA driver version required is R528 (R572 for GeForce RTX50 Series).
  • The minimum version of macOS required is 14.5. It will soon be raised to 15.
Changes since 2025.2
  • Fixed using shift+scroll to change values in the node inspector on macOS
  • Fixed issue causing the baking camera to output black renders when using triangles with motion.
  • Fixed rendering failure in some scenes with post volume effects
  • Fixed the Open Image Denoiser support for Nvidia Blackwell (5000 series) causing them to fallback to the CPU version.
Downloads
Downloads for Studio+ Subscription Users
OctaneRender Studio+ 2025.2.1 Standalone for Windows (Installer)
OctaneRender Studio+ 2025.2.1 Standalone for Windows (Zip Archive)
OctaneRender Studio+ 2025.2.1 Standalone for Linux
OctaneRender 2025.2 Standalone for macOS
OctaneRender Studio+ 2025.2.1 Node for Windows (Installer)
OctaneRender Studio+ 2025.2.1 Node for Windows (Zip Archive)
OctaneRender Studio+ 2025.2.1 Node for Linux
OctaneBench Downloads
OctaneBench 2025.2.1 for Windows
OctaneBench 2025.2.1 for Linux
*OctaneBench 2025.2.1 for macOS will be added shortly
OctaneBench 2025.2.1 Scene Files
Demo Downloads
OctaneRender Demo 2025.2.1 Windows (Installer)
OctaneRender Demo 2025.2.1 Windows (Zip archive)
OctaneRender Demo 2025.2.1 Linux
Happy rendering
Your OTOY team
nuno1980
Hello. :)
I got 1341 OB running Win 10 x64 22H2:
- i7-12700KF@stock
- RTX 4090 non-OC version@all stock speeds with Studio 576.02WHQL (HQ)
:D
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
J.C
Post fog still does not play well with volume objects.
System – Windows 11
manalokos
There is a shading bug where if 2 textures with OSL projection are mixed with a mix2colors they lose the OSL projection and use the standard UV's instead
john_otoy
manalokos wrote: Thu Jun 12, 2025 12:02 pm There is a shading bug where if 2 textures with OSL projection are mixed with a mix2colors they lose the OSL projection and use the standard UV's instead
Can you post an orbx?
manalokos
Here is a ORBX and the result in 2024.1 and 2025.2
It should behave as in 2024
john_otoy
manalokos wrote: Mon Jun 16, 2025 10:36 am Here is a ORBX and the result in 2024.1 and 2025.2
Thanks for the report
PolderAnimation
I looks like if you use multiple light (analytics on a standard surface shader) it does not add the specular correctly. I got very strong reflective renders. If I render my light separately and them in nuke it give the result I would expect. I cannot share my scene because of NDA unfortunately.
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
PolderAnimation
This is a problem I have addressed a couple of times. But hit is one that is in octane for a couple of years now. When render with an alpha and dof and using the desnoier it give very ugly artifacts around the edges.
john_otoy
PolderAnimation wrote: Wed Jul 09, 2025 9:56 am I looks like if you use multiple light (analytics on a standard surface shader) it does not add the specular correctly. I got very strong reflective renders. If I render my light separately and them in nuke it give the result I would expect. I cannot share my scene because of NDA unfortunately.
I have not been able to reproduce this, so we are going to need a sample scene.
Can you reproduce this if you reduce your scene to a single mesh (use a sphere) with the standard surface material plus your analytic lights? If so, please PM me with the simplified scene.
