OctaneRender® 2024.1.2 [current 2024]
mojave
Hi all,
This is a bug-fix release for 2024.1.1. Thanks again to all those who reported issues, and sent us feedback.
Important notes
  • The minimum NVIDIA driver version required is 522.
  • The GPU version of Open Image Denoise is supported on CUDA compute model 7 (Volta) and later. The CPU version is used on machines with older models, and on macOS.
  • The minimum version of macOS required is 14.5.
Changes since 2024.1.1
Fixes
  • Fixed a potential memory leak on Windows and Linux while updating scene instances.
  • Fixed magnitude of OSL differentials generated for UV projection when used in an environment map.
  • Fixed differentials on fisheye, cubic and orthographic cameras.
  • Fixed denoised render AOVs and volume mask render AOV containing an unintended alpha premultiplication when kernel alpha channel is enabled.
Downloads
OctaneRender Studio+ 2024.1.2 Standalone for Windows (installer)
OctaneRender Studio+ 2024.1.2 Standalone for Windows (ZIP archive)
OctaneRender Studio+ 2024.1.2 Standalone for Linux
OctaneRender 2024.1.2 Standalone for macOS
OctaneRender Studio+ 2024.1.2 Node for Windows (installer)
OctaneRender Studio+ 2024.1.2 Node for Windows (ZIP archive)
OctaneRender Studio+ 2024.1.2 Node for Linux
Happy rendering
Your OTOY team
nuno1980
Hello. :)
Yesterday, I detect nested dielectrics issue for fog (but not in environment node) and any solid/liquid specular (eg: glass, water...) material combo:
-- Nested dielectrics enabled
-- Nested dielectrics disabled
--> Nested dielectrics enabled of the spec material of ior 1.0 (eg: fog's or smoke's) must unchange the refraction of solid/liquid:
- priorities -:
-1 for fog and 0 for specular mat
or
-0 for fog and 1 for spec mat
FREE ORBX project - download:
Nested dielectrics test for volumetric fog and glass balls.orbx
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
nuno1980
Still no any response for almost 6 days ago from my past post...
Caustics at PT
i7-12700KF
32GB DDR4@3600
interelectronix
This is the wrong thread to post ;-)
nuno1980
interelectronix wrote:This is the wrong thread to post ;-)
Yeah. But not wrong because 2024.1.1 has my issue and 2024.1.2 too. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
frankmci
For quick response, it's always best to write to [email protected]. That will generate a support ticket with a trackable ID number and a set priority in the queue. Quick help on the forum is a courtesy, but it is not a formal support venue.
nuno1980
frankmci wrote:For quick response, it's always best to write to [email protected]. That will generate a support ticket with a trackable ID number and a set priority in the queue. Quick help on the forum is a courtesy, but it is not a formal support venue.
Already, the moderator has replied me but still no any solution. But I'll cut the indoor of fog's box to add spaces for objects (eg: balls...) under Blender because the developer doesn't fix nested dielectrics issue for fog yet. My ticket has been closed.
Thank you. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
