Cinema 4D version 2019.1.4-R2(Obsolete stable) 07.12.2019
Hi all,
This is new build with a stable version of 2019.1.4 SDK.
Any feedbacks are welcome for development and fixing the issues. Enjoy it!
This is the matching SDK for the 2019.1.4.
See all new features of 2018/2019 versions.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also, make sure you use a driver of version 419.xx or higher and if you are working on Mac OS that has a CUDA driver installed that supports at least CUDA 9.1.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
Changes of 2019.1.4-R2 C4D plugin
  • Missing first clone of multi-instances
  • Avoid lags due to unnecessary updates for VDB object under cloners
  • Performance fix for vdb object for viewport
  • Detection the animation for C4D noises
  • Fix: Custom lut strength
Changes of 2019.1.4 C4D plugin
- Directory selection option for osl scripts added
Changes of 2019.1.4 SDK
  • The overhauled auto-bump now supports all projection types and extra UV sets (see viewtopic.php?p=371750#p371750 for an example).
  • Improved auto-bump to preserve sharp edges of the geometry.
  • Fixed crash when you try to render a displacement mixer with an unconnected displacement pin (see viewtopic.php?p=371779#p371779).
  • Fixed toon rendering of bump/normal maps (see viewtopic.php?p=371859#p371859).
  • Fixed problem that a mixed universal material with 1.0 mix factor renders differently to a universal material - when there is some transmission involved.
  • Fixed render artefacts with specular materials that have an IOR between (1 .. 1.00005) (see viewtopic.php?p=371943#p371943).
  • Fixed missing thin film interference if RGB IOR or IOR + color is used in layered materials.
  • Fixed incorrect fake shadow colour if a vertex attribute texture is used in the transmission channel.
  • Fixed environment shadows missing in the general shadow pass.
  • Fixed error "unexpected primitive type 2" when you try to use the baking camera and displacement.
  • Fixed kernel failure if you render accurate rounded edges with the PMC kernel and a baking camera.
  • Fixed exception handling on MacOS which should reduce the delay/freeze during a crash.
Changes of 2019.1.3 C4D plugin
  • Fix: Timelimit option
  • Improvements in Node Editor, premade nodes for OSL scripts
  • NVLINK fix, devices fixes
  • Fix: crash in combination, osl texture float parameters(without sliderranges) with octane slider type
  • Fix: Some hanging situations of plugin on exit
Changes of 2019.1.3 SDK
  • Overhauled the auto-bump feature of vertex displacement, which fixes multiple issues that were reported. Now, auto-bump works with vector displacement maps as well and you can add an additional bump map on top of auto-bump.
  • Fixed direct lighting kernel looking different to v4 and 2018.1 when fake shadow is used + when a bunch of glossy materials with no diffuse and specular textures are used.
  • Fixed volume rendering in legacy mode (see viewtopic.php?p=369698#p369698).
  • Fixed a small memory leak when rendering is stopped.
  • Fixed wrong handling of extra arguments in the OSL environment() function.
  • Fixed a crash with a very long image file path.
  • Fixed minor bug in OSL compiler which breaks float val[2]; getattribute("camera:clip", val);.
WINDOWS ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... R2-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R21)
OSX ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R21)
R15-res.rar
(15.35 MiB) Downloaded 529 times
WINDOWS DEMO-BUILD (R15-R21)
https://render.otoy.com/plugindownloads ... R2-win.rar
OSX DEMO-BUILD (R15-R21)
https://render.otoy.com/plugindownloads ... Macosx.zip
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(419.x/431.84) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
Silverwing
Thank you very much Ahmet. Much appreciated!
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
Chriz
Thanks Ahmet! Thanks for updating constantly for ages now :D
http://www.C9W.de - Win10 - Dual E5 2620v3 - Display 1 GTX 1080 / Render 1 3090 RTX - 96 RAM - C4D MSA - C4D Plugin version: current - Standalone: current
GillesKontrol
We're going to have to clone Ahmet so the clone can start working on updates for the standalone 2019.2 too, they would be finished in a week! :D Thanks man for the update!
Seun116_1
Sheesh! Thanks, Ahmet! Appreciate your hard work!
Bulwerk
Can a vertex map be the input for the blend value in a Displacement mixer?
Scene file attached.
Fields driven vertex map as input
Only auto bump seems to come through using this method.
Gradient map as input
Vertex Map Displacement Mixer problem.zip
(271.31 KiB) Downloaded 425 times
frankmci
I still see a few minor issues with the new OSL options interface in the Node Editor:
1) Dragging out a new OSL node from the top "OSL Texture" side menu still produces the error
Unable to read file
file:///Users/UserName/Library/Preferences/Maxon/Maxon Cinema 4d R21_44CD9CB7/plugins/
c4doctane_2019.1.4/res/osl_scripts
But after hitting the OK button, the correct default OSL node is created.
2) I thought that the "OSL[/]" side menu item would show the root contents of the /osl_scripts directory, but it doesn't show anything when I put any scripts there. Am I missing something? Is there a way to define which directory that button links to?
3) The Show/Hide Category button for OSL at the top of the Node Editor only shows/hides the "OSL texture" button in the Side Menu, but it does not show/hide whole set of OSL sub categories, as I think it probably should.
This is under OS 10.12.6, C4D R21.
These are all relatively minor, and don't directly affect functionality.
As always, thanks for the quick update!
Bulwerk wrote:Can a vertex map be the input for the blend value in a Displacement mixer?
[/attachment]
Displacement is not supporting vertex color/maps as far as I know
Bulwerk
[/attachment]
Ohh that's such a shame. I'll be sure to request that it become part of the core.
Thanks for the response Aoktar!
Ron
Hi Ahmet,
I am referring to this thread:
viewtopic.php?f=85&t=73081&start=50#p372273
I did all that was advised:
1-Downgrade to Studio 431.84 with CLEAN install
2-Use a default layout
3-Delete prefs folder for testing and remove all other plugins for testing
I tried this with both V 2019.1.3 and 2019.1.4 with no luck. C4D always freezes - mostly after entering node editor.
This is kind of annoying :-(
I made this screen capture:
https://www.dropbox.com/s/vhk03wd84m8h4 ... 1.mp4?dl=0
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
