OctaneRender™ Standalone 2.26.1 [current 2.xx]
abstrax
Hi all,
Since 2.26 reduced the PMC performance on pre-Pascal GPUs and PMC didn't run on Pascal GPUs at all, we had to switch back to CUDA 6.5 for pre-Pascal GPUs and enable PMC for Pascal GPUs.
Unfortunately using CUDA 6.5 + 8.0 for Pascal GPUs, crashes the PMC kernel, forcing us to use CUDA 7.5 + 8.0 for Pascal GPUs, which means that PMC runs a little bit slower on Pascal GPUs than on the corresponding Maxwell GPU. Since we don't have the resources to investigate this problem further, there isn't much we can do here about it.
There are no other changes compared to version 2.26.
Downloads:
Windows
- 64-bit commercial version (installer)
- 64-bit commercial version (ZIP archive)
Mac OS X
- 64-bit commercial version (DMG image)
Linux
Happy rendering,
Your OTOY NZ Team
blackshore
Alright. So I can use both 780 and 1070 in the same machine but the 1070 will be a bit slower on PMC but pathtracing is unaffected?
nuno1980
I can back to normal performance! Thank you! :)
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
p3taoctane
Thanks for this build
Much appreciated
itsallgoode9
so should pathtracing be slower as well? here are my results on a scene in standalone:
standalone, 2.26.1:
1080 gpu: pathtrace @ 4.71-ish Ms/sec
780 gpu: pathtrace @ 5.56-ish (periodic bouncing up to 6.0+) Ms/sec
standalone, 2.26.0:
nuno1980
itsallgoode9 wrote:so should pathtracing be slower as well? here are my results on a scene in standalone:
standalone, 2.26.1:
standalone, 2.26.0:
Same speeds only between versions!?
Caustics at PT
i7-12700KF
32GB DDR4@3600
itsallgoode9
standalone, 2.26.1:
standalone, 2.26.0:
yeah, for me, i'm only seeing 15-20% increase in speed between a non Ti 780 and a 1080 FTW. I tested the two different versions to make sure it's not a version issue. Also, I checked the time to reach a set shading level and it too is only 15-20% difference.
Notiusweb
Figured I'd go Old School here with V2...
Could you add Adaptive Sampling to the V2 for Mega Speed, that would be cool.
Regards,
Notiusweb
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
abstrax
Notiusweb wrote:Figured I'd go Old School here with V2...
Regards,
Notiusweb
No, there won't be any further development on v2.
Notiusweb
Regards,
Notiusweb
Then, Brigade it is!
Does a Summer 2017 release date work, thanks! :D
Thanks always,
Notiusweb
Plugs: Enterprise
