Octane Snow
dotcommer
My result after attempting to create a realistic looking "fresh snow" material. Just a single diffuse texture with a mix of perlin and turbulent noise in the displacement and some absorption. Check the progress and project file here (C4D):
http://render.otoy.com/forum/viewtopic. ... 52#p230452
Download my free Octane resources!
Paper Lantern | Fresh Snow (C4D Only) | Keyboard Displacement Texture | Solar Panel Texture
Mac Pro (2012) | 2x6Core 3.06GHz | 64GB | 1 x Titan Black 6GB
Portfolio: http://www.deltawavefx.com
wastzzz
Quite beautiful.
M.
Buraq
I love it!!! Great work.
prodviz
Very nice. Are you using only procedural for displacement?
Elvissuperstar007
Add in the online library
dotcommer
prodviz wrote:Very nice. Are you using only procedural for displacement?
Yup! Only procedural noise from Octane.
ElBloko
Procedural noise for displacement? How did you manage that? Does octane now allow for procedural textures to be used as displacement?
3rdeye
looks nice...but needs little improvement...good progress though
nuno1980
Snow - Diffuse material!??? Seems no because your scene isn't equal to the real life... But yes should change material to "specular" due to like a bit "ice". ;)
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
ElBloko wrote: Procedural noise for displacement? How did you manage that? Does octane now allow for procedural textures to be used as displacement?
hi ElBloko,
not properly, there is a special option in the c4d integrated plugin made by aoktar that let us use any c4d procedural shader that will be baked on the fly as texture image and can be used with octane displacement ;)
Basically, is like to use the standalone lua script for generating noise texture from procedurals, so is just a workaround, but it could be very useful and easy to use. On the other hand, some bad tiling effects could happen.
I don't know if other plugins have the same option.
