Octane won't render
Jorgensen
Hi
I've just got this problem today.
When I open the Octane window, nothing happens :-/
I have tried both repair and reinstall the octane plugin, and removed all other plugins from
C:\Users\bre\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
The standalone version and 3ds max plugin runs fine.
Does anyone know what might be the problem?
Sketchup pro 2014 v14.1.1282
Octane standalone 2.06
Octane plugin 0.11.53
fuzzybro
Hi Jorgensen,
Don't panic, help is on the way :D
1) Could you please send me a couple of recent log files?
They are here:
C:\Users\USERNAME\Documents\Octane\SketchUp\logs
2) And could you please export scene to .ocs/.orbx? To export, open Octane Viewport and then in Sketchup Select Plugins -> Octane -> Export to .ocs
You can attach needed files here or in PM. I'll check what might be wrong.
Thanks!
Jorgensen
Hi Fuzzybro
Here are the files.
logs.zip
(11.6 KiB) Downloaded 275 times
scene.ocs
(20.94 KiB) Downloaded 301 times
Jorgensen
Hi Fuzzybro
Do you have any ideas what causes the problem?
fuzzybro
Hi Jorgensen,
I'm going to check it right now.
Based on the logs everything is initialized and should work fine.
Did you manage to run Octane for Sketchup previously? Demo version or different SU version?
As a quick check, could you disable firewall and try launching Sketchup again?
Jorgensen
Hi fuzzybro
I have been able to run the same octane for sketchup fine before . I have to tried to deactivate via octane menu, but the deactivate but the button is somehow grayed out.
fuzzybro
What was the change that made it stop working? Updated to a new version?
When you press "Deactivate" it takes some time to actually do the deactivation.
Also, could you please open octane materials window? Is it working?
Jorgensen
Hi Fuzzybro
I can open materials window, and it works just fine.
I've got a new router, that might be the problem?
Can't deactive even if I wait very long.
I can add that both the standalone and the 3ds max plugin works fine.
Jorgensen
Hi Fuzzibro
I forgot to mention that I installed Sketcup 2014, while still having Sketchup pro 8 installed.
I just opened Sketchup pro 8, and the Octane plugin works just fine in here, but again I can't select deactivate :-/
fuzzybro
Wow, that's super weird.
Ok, try deleting license.cfg file located in C:\Users\%USERNAME%\Documents\Octane\SketchUp
and then deactivating SU license in your Customer Area page http://render.otoy.com/account/octanelive.php
This will help you to deactivate.
As for rendering issue, wait for new build, I'll prepare it this week, it might solve some problems.
Return to “SketchUp”
