polygons show in rendering
gueoct
Anybody seen this before? is this a memory issue?
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
t_3
no image? ;)
gueoct
Sorry; here we go again:
t_3
quite sure not a memory issue. can't really tell from the image, but the first thing to look for would be imo the scene scale. this is often mismatched while import objects, and octane is showing artifacts on kilometers large objects. you may also try to lower ray_epsilon and see if this helps...
gueoct
rayepsilon is at 0,0.
scale is 1200 cm x 600 cm...
t_3
gueoct wrote:rayepsilon is at 0,0.
can you upload the scene? would be easier to check what could be the problem...
be_fast
You should make reset Xform and if it does not halp just make a box with similar scale and attach your object to this new-created box. Then go to elements in the editable poly and delete box element
Hope its gona work
asus p8b ws [email protected] RAM-16gb and 3xGTX580 3gb I love octane and you guyz doing amazing job for us, THANK YOU
Return to “Autodesk 3Ds Max”
