Anybody seen this before? is this a memory issue?
polygons show in rendering
quite sure not a memory issue. can't really tell from the image, but the first thing to look for would be imo the scene scale. this is often mismatched while import objects, and octane is showing artifacts on kilometers large objects. you may also try to lower ray_epsilon and see if this helps...
„The obvious is that which is never seen until someone expresses it simply ‟
can you upload the scene? would be easier to check what could be the problem...gueoct wrote:rayepsilon is at 0,0.
scale is 1200 cm x 600 cm...
You should make reset Xform and if it does not halp just make a box with similar scale and attach your object to this new-created box. Then go to elements in the editable poly and delete box element
Hope its gona work
Hope its gona work
asus p8b ws [email protected] RAM-16gb and 3xGTX580 3gb I love octane and you guyz doing amazing job for us, THANK YOU
