Cinema4D version 2021.1.4-(R4) (Stable 2021) 21.04.2022
bloomis2
Hi, does anyone know how the xp groups are supported? When I put an octane tag on an xp group, the "particle rendering" tab is not here
Kalua
Kalua wrote:
SSmolak wrote:After changing LV camera behavior Octane stopped updating materials - if new polygons are included or excluded from material tag or new material is added to objects. There is need LV restart to update them.
I have noticed Camera movement has started to not update in LV window in some cases: when I am using "Takes", and I copy the set camera and keep using the Take set camera, I need to change the set camera and back to make it responsive in the Liveview window.
I may make a video if it sounds too confusing to understand.
Otherwise R4 is working great!
Regards,
This is the kind of behavior it has been happening lately (with or without use of "Takes"). Not updating camera and shaders mainly:
Regards,
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
thanulee
bloomis2 wrote:Hi, does anyone know how the xp groups are supported? When I put an octane tag on an xp group, the "particle rendering" tab is not here
See attachment please
xpGroups_Octane.7z
(48.44 KiB) Downloaded 265 times
dasmodular
Particle rendering doesn't work at all for us with R4, we went back to R1
dasmodular wrote:Particle rendering doesn't work at all for us with R4, we went back to R1
Better to give more info, not sure what are you talking about!
bloomis2
Thank you Thanos! ;)
dasmodular
I tried 3 xpGroups and it doesn't work.
Please have a look into the attached file.
C4D R25 Octane 2021.1.4-(R4) X-Particles 1253
3xpGroups_Octane.zip
(83.96 KiB) Downloaded 257 times
dasmodular wrote:I tried 3 xpGroups and it doesn't work.
Group numbers are also indexes for the assigned geometries in current implementation. It may need a fix or not, not sure yet. Can't work on because of 2022 works. But if you add three objects to list in objects tags then it will work.
thanulee
Does this file work for you? I tried with many groups, all modes of group distribution, geometry as children etc.
I'm in r23 / xp build 1253 and everything works fine, materials too.
xpGroups_Octane_update.7z
(64.15 KiB) Downloaded 242 times
glimpse
Not sure if it's a bug or simply changed workflow. Could anyone from C4D plugin guys could take a look into this?
https://www.facebook.com/groups/OctaneR ... 403752726/
