Cinema4D version 2021.1.4-(R4) (Stable 2021) 21.04.2022
This is the kind of behavior it has been happening lately (with or without use of "Takes"). Not updating camera and shaders mainly:Kalua wrote:I have noticed Camera movement has started to not update in LV window in some cases: when I am using "Takes", and I copy the set camera and keep using the Take set camera, I need to change the set camera and back to make it responsive in the Liveview window.SSmolak wrote:After changing LV camera behavior Octane stopped updating materials - if new polygons are included or excluded from material tag or new material is added to objects. There is need LV restart to update them.
I may make a video if it sounds too confusing to understand.
Otherwise R4 is working great!
Regards,
Regards,
Octane User since V1 Beta
See attachment pleasebloomis2 wrote:Hi, does anyone know how the xp groups are supported? When I put an octane tag on an xp group, the "particle rendering" tab is not here
- xpGroups_Octane.7z
- (48.44 KiB) Downloaded 273 times
- dasmodular
Particle rendering doesn't work at all for us with R4, we went back to R1
Better to give more info, not sure what are you talking about!dasmodular wrote:Particle rendering doesn't work at all for us with R4, we went back to R1
- dasmodular
I tried 3 xpGroups and it doesn't work.
Please have a look into the attached file.
C4D R25 Octane 2021.1.4-(R4) X-Particles 1253
- 3xpGroups_Octane.zip
- (83.96 KiB) Downloaded 264 times
Group numbers are also indexes for the assigned geometries in current implementation. It may need a fix or not, not sure yet. Can't work on because of 2022 works. But if you add three objects to list in objects tags then it will work.dasmodular wrote:I tried 3 xpGroups and it doesn't work.
Does this file work for you? I tried with many groups, all modes of group distribution, geometry as children etc.dasmodular wrote:I tried 3 xpGroups and it doesn't work.
I'm in r23 / xp build 1253 and everything works fine, materials too.
- xpGroups_Octane_update.7z
- (64.15 KiB) Downloaded 256 times
Not sure if it's a bug or simply changed workflow. Could anyone from C4D plugin guys could take a look into this?
https://www.facebook.com/groups/OctaneR ... 403752726/
