Cinema4D version 2021.1.4-(R4) (Stable 2021) 21.04.2022
Hi all,
This is the latest stable plugin build based on 2021.1.4 SDK. Any feedback will be much appreciated. Enjoy it!
This is the SDK matching Standalone 2021.1.4.
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows. No driver updates are required for macOS 10.13 (CUDA).
This version supports the new NVIDIA Ampere architecture on Windows and Linux. Kepler cards with compute model lower than 3.5 are just supported on macOS.
Changes of 2021.1.4-(R4) plugin
- xpGroup object support
- R26 builds
Changes of 2021.1.4-(R3) plugin
- Missing AOV parameters of sub material
- Fix: a crash with Background object
Changes of 2021.1.4-(R2) plugin
- Better camera navigation in LV
- Fix: wrong color values with MoGraph colors on some cases like having nested multi cloners
Changes of 2021.1.4 plugin
- Fixed wrong AOV number in capture AOV
- Added new options for composite AOV layer node
Core changes since OctaneRender 2021.1.3:
  • Added "Legacy blend mode" alpha operation and a "Force premultiply opacity" pin to the composite AOV layer node. These options allow you to reproduce the results seen in older scenes, before fixes were made in 2021.1.2.
  • Reverted the cleanup of the resolution node. I.e. all resolutions we had in version 2020.2 and before are available again, plus the more modern resolutions we introduced in 2021.1.
  • Small performance improvement for non-RTX ray-tracing.
  • Improved startup times, especially on Linux.
  • Map range output AOV node will now allow the output minimum value to be higher than the output maximum value.
  • If an OctaneLive activation fails due to an interrupted Internet connection, we open a retry dialog and try again automatically after 20 seconds.
  • Fixed authentication failures when more than 4 Octane processes try to authenticate on Linux. If a failure still occurs, we open a retry dialog and try again automatically after 4 seconds.
  • Fixed incorrect rendering of materials that use a dirt texture as input of any of the channel manipulation textures (like Channel merger or Channel mapper).
  • Fixed incorrect rendering of OSL textures that have an unconnected _sdf input.
  • Fixed black pixels on materials that emit and which have an opacity of 0 or a general visibility of 0.
  • Fixed incorrect values in volume Z-depth front AOV.
  • Fixed render hang when you use the baking camera is a scene with displacement triangles.
  • Fixed auto bump which may cause artefacts on vertex displacement materials that projections other than UV mapping.
  • Fixed copy and pasting a geometric primitive, where the first change of the primitive type of the copied geometric primitive was ignored.
  • Fixed crash when you load the "fun with vectron" example scene.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
WINDOWS ENTERPRISE BUILD (R15-R26)
https://render.otoy.com/customerdownloa ... R4-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R26)
WINDOWS DEMO BUILD (R15-R26)
https://render.otoy.com/plugindownloads ... R4-win.rar
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.117, R26.013). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Kalua
Thank you, team!
C4D 2026.1 v1.8.2 // Octane 2026.1, <<2 X 3090 + NVlink>>, Windows 11 Pro, X399, AMD TR 2950X, 128 GB RAM, NVIDIA SD 560.94
Octane User since V1 Beta
pxlntwrk
It didn't drag! :D
thanks
pxlntwrk.net
SSmolak
In render settings while using ocio if looks is set to use view look - it doesn't match. It needs to be manualy put here proper look.
SSmolak wrote:In render settings while using ocio if looks is set to use view look - it doesn't match. It needs to be manualy put here proper look.
Because each one is different by design and usage and this design is not belong to me. One is for viewing purposes, other is for saving the file with the look. Iterated values is readed by SDK as you can see.
paypal-ict
Which OCIO profiles are you using if I may ask?
Could you share a download link?
SSmolak
paypal-ict
SSmolak wrote:Blender Flimic Ocio : https://sobotka.github.io/filmic-blender
But when you use for instance the "Very High Contrast"-look, wouldn't that mean it is tonemapping your picture?
As in: destroying your 32 bit OCIO/Aces-data?
SSmolak
Yes it "flatten" 32bit tone range to 8bit. This is exactly the same as you can do in Photoshop Camera Raw plugin but it make it very inteligent. If you don't have time to make it manually after rendering this is the way to go. One bad thing is that it take into consideration background too ( HDRI or Sky )
SSmolak
Octane doesn't show materials from XRef objects and when they are loaded Octane status is going crazy - it blinking "check others time : ....."
