OctaneRender™ Standalone 3.08 TEST 6
aufwind
There's a mismatch of RGB Values:
Win7 | Gigabyte G1.Sniper 3 | I7 3770K | 2x Titan (Kepler) | 1x Titan X (Pascal)
abstrax
aufwind wrote:There's a mismatch of RGB Values:
The attachment Color-Values.jpg is no longer available
The node inspector displays the RGB values that are stored in the node. The RGB values in RGB texture nodes are always in linear color space. On the other hand, the color picker allows you to enter colors either as sRGB values or as linear values, which can be defined in the application preferences:
I.e. if you would set the color picker space to "linear", both color values would match.
Rik
Is displacement now at a stage where it will work around corners without creating cracks - I've always had to use geometry to make brick and mortar walls as the bricks always had cracks.
coilbook
when is AI noise removal coming out? Seems that redshift is working on it too https://youtu.be/2vJ_5nPVU0s?t=10s
Thank you
mvijfwinkel
Hey, so is it possible to setup entirely Roughness-controlled specular (including fresnel, ior etc) now?
Studio21
@coilbook 3.09
renderingz
Will Octanes voxelisation-displacement ever support vertex motion blur? The last two commercial projects i've done have needed vertex motion blur on displaced meshes.
Win `10/ Cinema 4D R17 / 2 x 780 GTX 6GB + 2 x 980ti
Goldorak
coilbook wrote:when is AI noise removal coming out? Seems that redshift is working on it too https://youtu.be/2vJ_5nPVU0s?t=10s
Thank you
https://www.facebook.com/groups/OctaneR ... 952490617/
FrankPooleFloating
:shock: YES!!!
But once again G, can you please post updates (at least shocking eye-bulging ones like this -- for us antisocial types) in the latest Development Build Release section every single time you post good stuff on FB? That would really rock big guy.
pegot
FrankPooleFloating wrote::shock: YES!!!
+1
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
