OctaneRender™ Standalone 3.08 TEST 6
The node inspector displays the RGB values that are stored in the node. The RGB values in RGB texture nodes are always in linear color space. On the other hand, the color picker allows you to enter colors either as sRGB values or as linear values, which can be defined in the application preferences: I.e. if you would set the color picker space to "linear", both color values would match.aufwind wrote:There's a mismatch of RGB Values:
when is AI noise removal coming out? Seems that redshift is working on it too https://youtu.be/2vJ_5nPVU0s?t=10s
Thank you
Thank you
- mvijfwinkel
Hey, so is it possible to setup entirely Roughness-controlled specular (including fresnel, ior etc) now?
- renderingz
Will Octanes voxelisation-displacement ever support vertex motion blur? The last two commercial projects i've done have needed vertex motion blur on displaced meshes.
Win `10/ Cinema 4D R17 / 2 x 780 GTX 6GB + 2 x 980ti
https://www.facebook.com/groups/OctaneR ... 952490617/coilbook wrote:when is AI noise removal coming out? Seems that redshift is working on it too https://youtu.be/2vJ_5nPVU0s?t=10s
Thank you
- FrankPooleFloating
But once again G, can you please post updates (at least shocking eye-bulging ones like this -- for us antisocial types) in the latest Development Build Release section every single time you post good stuff on FB? That would really rock big guy.
+1FrankPooleFloating wrote:YES!!!
Win 11 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
