You won't see a difference between using an RGB color vs a greyscale color. For glass you normally use an IOR around 1.5, and both reflection and transmission set to 1.0. You have to make sure normals are pointing in the correct direction.
Roeland
Glasses at PMC - caustics smooth - fail!?
How do I enable normal map
Normal map?
But ~64k-sample is good for almost true glasses.
Ok but I set reflection 0.5.roeland wrote:You won't see a difference between using an RGB color vs a greyscale color. For glass you normally use an IOR around 1.5, and both reflection and transmission set to 1.0. You have to make sure normals are pointing in the correct direction.
Roeland
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
NEW ACER Predator XB273U F5 27"
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
