Glasses at PMC - caustics smooth - fail!?
nuno1980
Hi! :)
Glasses have 1.36 millions of polygons!! :) But...
Due to have any limitations for PMC kernel?
see screenshots:
-wireframe
-glasses setting
-Mat (liquid) setting
-PMC kernel setting
How do I remove "fail"?
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
FooZe
Are you happy to zip and post the obj for one of these glasses and let me have a try?
(or email to [email protected] Attention Chris.)
nuno1980
FooZe wrote:Are you happy to zip and post the obj for one of these glasses and let me have a try?
Ok, I have sent to support by email. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
FooZe
Hi, i have been having a play with the scene. Depending on what process i put the OBJ through before rendering i get different results.
ie: I have loaded it into blender, removed the un-necessary geometry then rendered in blender, exported as OBJ again, rendered in the standalone and also imported the obj into C4D and rendered there.
I think a few things could be tweaked:
1) Use less max depth, i know it gives a lot of intricate caustics, but this is probably causing your problem. Far to many bounces means you see all sorts of things and have no idea where they are coming from (it also makes the render slower).
2) Double check your settings on export - check if you are exporting normals (if not try turning it on).
3) Add some caustic blur, even if you want crisp caustics - using something like 0.001 or even 0.0001 will increase render speed of caustics and shouldn't blur them too much.
4) Try using a lower parallelism (3,2 or even 1).
5) Double check scale. I had scale the scene by 0.0001 to get it the right size on import into blender. (and use something other than meters on import into the standalone).
To confirm if it's a OBJ export problem you could try the demo of the c4d plugin (it looked like it was exported from c4d?) and see if you get the same results.
Hope that's not information overload!
Chris.
nuno1980
@FooZe: Sorry, I have sent by email on today (11:27am UTC). But I read here now and will try... ;)
I want keep max depth 32 for especially objects mirrored and/or speculars (eg: glasses...) because the difference between 16- and 32-depth is little - 32-depth is less dark "glitch".
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
Oh! I haven't Cinema4D...
Caustics at PT
i7-12700KF
32GB DDR4@3600
MaTtY631990
Why so many polys for the glasses, anyway. Is this is just testing for limits you are doing here.
nuno1980
New OR 1.5 fixed my issue. :) But specular material for glass hasn't "floattexture"!??? :? What's name succeed "floattexture"?
WARNING: But I'm very worried due to "water marks" added despite I don't want to render animation. But the developer may be maked mistake because the information doesn't say "water marks" for standalone demo. I respect remove "water marks" but to lock to save image fixed and animation for demo.
Caustics at PT
i7-12700KF
32GB DDR4@3600
roeland
The floattexture is now called greyscale color.
Roeland
nuno1980
@roeland: Ok, I tried to change 0.500 (reflection) and 1.000 (transmission) in greyscale for glass/water material but looks glass/water very mirrored. Before, 1.20 is excellent - floattexture (reflection w/ 0.5 and transmission w/ 1.0) for glass/water. :(
Caustics at PT
i7-12700KF
32GB DDR4@3600
