Glasses at PMC - caustics smooth - fail!?
roeland
You won't see a difference between using an RGB color vs a greyscale color. For glass you normally use an IOR around 1.5, and both reflection and transmission set to 1.0. You have to make sure normals are pointing in the correct direction.
Roeland
nuno1980
How do I enable normal map
roeland wrote:You won't see a difference between using an RGB color vs a greyscale color. For glass you normally use an IOR around 1.5, and both reflection and transmission set to 1.0. You have to make sure normals are pointing in the correct direction.
Roeland
Ok but I set reflection 0.5. :) Normal map?
But ~64k-sample is good for almost true glasses. :)
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
