Ok. But any AMD Radeon RX card isn't be supported by OctaneRender yet. But at LuxMark test (NOTE: http://luxmark.info - page is wrong for be discontinued, unfortunately), RX 9070 XT is (much) slower than RTX 4090 while RX 9070 XT is as faster as or is little faster than RX 7900 XTX.Elvissuperstar007 wrote: Tue Mar 03, 2026 12:02 amI'll be going AMD I hear the 9070xt is running great on reddit and they paid half the price I did for this hunk of technology failure. Thanks for listening any tips are welcomed!
OctaneRender® 2026.2
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
NEW ViewSonic XG2431 24"
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
- Elvissuperstar007
- Contact:
DDU will not help you get rid of the black screens — this is what actually fixes it.
How to Perform a Clean Shut Down Using Shift
Click Start
Click the Power button
Hold the Shift key
While holding Shift, click Shut down
Keep holding Shift until the PC fully powers off
⚠ Important:
Use the Windows power menu, not the physical button on your PC case.
Keep holding Shift until the screen turns off and the fans stop.
After that, turn the PC back on normally using the power button.
Click Start
Hold the Shift key
⚠ Important:
Ok. I don't need to shutdown PC power after DDU used. But if any dust is on your PC tower and on indoor of your videocard, should clean all dust because dust causes abnormally increased temperatures of your GPU.Elvissuperstar007 wrote: Tue Mar 03, 2026 5:49 pm DDU will not help you get rid of the black screens — this is what actually fixes it.
Click Start
Hold the Shift key
⚠ Important:
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
Please keep this discussion for Standalone 2026.2 issues only. This is not directly related to it, and we have a specific forum section for hw issues:Elvissuperstar007 wrote: Mon Mar 02, 2026 6:03 pm https://www.nvidia.com/en-us/geforce/forums/game-ready-drivers/13/582537/black-screen-crashes-help-needed/
SOLVED (atleast for now) havent had crashes for a few days now, will keep updating.
viewforum.php?f=11
Happy GPU rendering!
ciao,
Beppe
- Elvissuperstar007
- Contact:
Ok. But lastest version of the Dali Renderer software is on December 2024 and this software doesn't have any dispersion (dispersion coefficient or Abbe Number) option for refraction. This sw doesn't support any GPU - too bad.Elvissuperstar007 wrote: Thu Mar 05, 2026 6:31 am Interesting development, fast caustics are always good
https://www.dalirenderer.ru/examples/
WOW!
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
This is usually a sign that the Octane executable is corrupted, likely due to a download or filesystem issue. Could you please download again and reinstall?MIaxd wrote: Mon Apr 13, 2026 4:08 am I have a subscription license, but a watermark appears when I disconnect the camera's image sensor node.
Please let us know if you still have the same issue after that, including the output of your log window.
This issue occurs when using the Chinese version; the English version works fine.mojave wrote: Mon Apr 13, 2026 4:12 amThis is usually a sign that the Octane executable is corrupted, likely due to a download or filesystem issue. Could you please download again and reinstall?MIaxd wrote: Mon Apr 13, 2026 4:08 am I have a subscription license, but a watermark appears when I disconnect the camera's image sensor node.
