Non-offical Blender 2.56 plugin
yoyoz
I think I got the point. Please check out v0.43, it should fill your needs :-)
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
SamCameron
Wow ! you're amazing, I'll try as soon as I back to home, one question... is this new method for render groups limited to empty objects? or can be also applied to normal objects aswell?
yoyoz
The original script only exported objects of type 'MESH', 'SURFACE', 'META', 'TEXT' and, 'CURVE'. I've only added 'EMPTY' to the list for your scene to render properly, but again, I don't know if this has side effects...
yoyoz
Please skip v0.43 and go to 0.44 (see release notes)
r0ug3r
hi, i have downloaded the script, i followed the instructions to export but i have some error and octane doesn't continue
pls help.....attached is the image. thanks so much..
yoyoz
Hi, please start blender from command line and post the output here, I need to see what was the full command generated by the script.
steveps3
I've been giving the hair render a quick trial. It works a treat.
(OS) Windows 7(64)
SamCameron
The group render works perfect!, the only thing is not working when the duplication group is from an object instead of an empty, check this file:
EDIT:
another matter, I get this error when I'm trying to render with Octane by the script:
groupsV2.zip
(62.43 KiB) Downloaded 378 times
yoyoz
I' m getting 3 cubes when rendering in both Octane and Blender (and not the plane). What's the expected behaviour?
Regarding your error, you have a special character in an object name. Disabling logs may work but I strongly recommend you rename properly the offending object.
yoyoz
v0.50 online, please check initial post.
Return to “Blender”
