Non-offical Blender 2.56 plugin
I think I got the point. Please check out v0.43, it should fill your needs
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
- SamCameron
Wow ! you're amazing, I'll try as soon as I back to home, one question... is this new method for render groups limited to empty objects? or can be also applied to normal objects aswell?
The original script only exported objects of type 'MESH', 'SURFACE', 'META', 'TEXT' and, 'CURVE'. I've only added 'EMPTY' to the list for your scene to render properly, but again, I don't know if this has side effects...
Please skip v0.43 and go to 0.44 (see release notes)
Hi, please start blender from command line and post the output here, I need to see what was the full command generated by the script.
- SamCameron
The group render works perfect!, the only thing is not working when the duplication group is from an object instead of an empty, check this file:
EDIT:
another matter, I get this error when I'm trying to render with Octane by the script:
EDIT:
- groupsV2.zip
- (62.43 KiB) Downloaded 366 times
I' m getting 3 cubes when rendering in both Octane and Blender (and not the plane). What's the expected behaviour?
Regarding your error, you have a special character in an object name. Disabling logs may work but I strongly recommend you rename properly the offending object.
v0.50 online, please check initial post.
