The text comes out blurry.
Windows 3840-2160 150% Scale
Cinema4D version 2021.1.5-(R4) (Stable 2021) 28.06.2022
- eyeonestudio
- Contact:
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
I know, not yet added scaling supporteyeonestudio wrote:The text comes out blurry.
You can try the following:thanulee wrote:I d like to set HSV to default as well if possible!moebius wrote:oh, no!
Why did you changed that position? It's so far away. I prefere HSV and have tp change that so many times. Or is there a way to set HSV permanent?
1.Open Cinema 4D‘Preferences》Units》’,choice ‘HSV mode’
See 01 picture for details
2.Open‘Octane settings 》Settings》Other’,switch‘Color gui type’to ‘Cinema 4D native’,Click ‘Apply’
See 02 picture for details
HSV is now the default color mode.
The method may not be very clever
Thanks I always forget to change that! Its great method actuallyHurricane wrote:You can try the following:thanulee wrote:I d like to set HSV to default as well if possible!moebius wrote:oh, no!
Problem with textures and exr files that I reported in other post is that all textures that are dragged from outside C4D are automatically moved to tex folder instead of be a part orginal path folder storage.
Try to do with a saved scene.SSmolak wrote:Problem with textures and exr files that I reported in other post is that all textures that are dragged from outside C4D are automatically moved to tex folder instead of be a part orginal path folder storage.
Hi,911ljt wrote:in 2021.1.5, use Group node function to group any node together will guarantee a crash! Please fix urgently!
I notice this behavior too, but only with the "New Style" node editor, however works fine with the old style.
pxlntwrk.net
pxlntwrk.net
Don't know how you do! Any video will help to understand. BTW new addon is work in progress and taking time to change every function which is using graphics. You can report issues and switch to old style until fix done. In this period 2021 is not only work I do, 2022.1 is taking time. No pressure,making rush that's just causing more issues911ljt wrote:in 2021.1.5, use Group node function to group any node together will guarantee a crash! Please fix urgently!
