Cinema4D version 2021.1.5-(R4) (Stable 2021) 28.06.2022
eyeonestudio
The text comes out blurry.
Windows 3840-2160 150% Scale
CINEMA 4D R2025
Win11 / AMD 7995WX, 3995WX, 3990X, Intel 10980XE / 256Gb RAM / RTX4090, RTX3090 / 100GbE, 40GbE, 10GbE
eyeonestudio wrote:The text comes out blurry.
I know, not yet added scaling support
Hurricane
thanulee wrote:
moebius wrote:oh, no!
Why did you changed that position? It's so far away. I prefere HSV and have tp change that so many times. Or is there a way to set HSV permanent?
The attachment Bild_2022-05-16_145144768.png is no longer available
I d like to set HSV to default as well if possible!
You can try the following:
1.Open Cinema 4D‘Preferences》Units》’,choice ‘HSV mode’
See 01 picture for details
2.Open‘Octane settings 》Settings》Other’,switch‘Color gui type’to ‘Cinema 4D native’,Click ‘Apply’
See 02 picture for details
HSV is now the default color mode.
The method may not be very clever
thanulee
Thanks I always forget to change that! Its great method actually
SSmolak
Problem with textures and exr files that I reported in other post is that all textures that are dragged from outside C4D are automatically moved to tex folder instead of be a part orginal path folder storage.
SSmolak wrote:Problem with textures and exr files that I reported in other post is that all textures that are dragged from outside C4D are automatically moved to tex folder instead of be a part orginal path folder storage.
Try to do with a saved scene.
911ljt
in 2021.1.5, use Group node function to group any node together will guarantee a crash! Please fix urgently!
Thank you!
pxlntwrk
911ljt wrote:in 2021.1.5, use Group node function to group any node together will guarantee a crash! Please fix urgently!
I notice this behavior too, but only with the "New Style" node editor, however works fine with the old style.
pxlntwrk.net
Don't know how you do! Any video will help to understand. BTW new addon is work in progress and taking time to change every function which is using graphics. You can report issues and switch to old style until fix done. In this period 2021 is not only work I do, 2022.1 is taking time. No pressure,making rush that's just causing more issues
moebius
thanulee wrote: You can try the following:
thanks!
Return to “Releases”
