This is the latest stable plugin build based on 2021.1.5 SDK. Any feedback will be much appreciated. Enjoy it!
This is the SDK matching Standalone 2021.1.5.
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows. No driver updates are required for macOS 10.13 (CUDA).
This version supports the new NVIDIA Ampere architecture on Windows and Linux. Kepler cards with compute model lower than 3.5 are just supported on macOS.
Changes of 2021.1.5-(R4) plugin
- Removed 'orthographic' from universal camera UI
- Fix: Undo shortcut issue when embedded GUI focused
- Added: 'Add input' and 'Add mask' button functionality for "Composite AOV output layer"
- Fix for missing functionalities of embedded GUI
- Using Linear color space when straight alpha enabled in file save section
- ORBX loader: Fix for double displayed object and object color is not working for display
Changes of 2021.1.5-(R3) plugin- Fix: Undo shortcut issue when embedded GUI focused
- Fixes on node editor
- Added a new high quality Node Graph drawing mode. It's just for R22-R26 for now. You can switch between legacy/new with 'New style' check box.
- Fix: absolute path on Image texture creations in Node Editor
- Added an option to let disable the file select dialog for Image texture creation in Node Editor
- Added new Vectron operators(Subtract/Union)
- Ability of using the SDFs as in input for Vectron objects
- Fix: orientation problems with scatter object
- Small addon for Octane Color gui, open/close button for sliders
- Several minor fixes and SDK(core) related changes
Core changes since OctaneRender 2021.1.4:
- Added new option to toggle bump/normal mapping for the ambient occlusion AOV.
- Added option to the volume Z depth AOVs that allows you define which depth is considered white (1).
- Added new pin Input axes to the vertex displacement node which provides the ability to choose between different ways how the XYZ coordinates of a vector map should be interpreted in object space. This may be particularly important if your source application works in a left handed coordinate system.
- Fixed an issue where SSS + fake shadow enabled was rendering too dark when it sits inside another specular material that has fake shadow enabled.
- Fixed Vectron geometry becoming invisible if the bounds pin is unconnected. We now use the default bounds in that case which are 10m x 10m x 10x.
- The Bounds input of Vectron nodes doesn't allow negative values anymore and will be clamped at 0. Old scenes with negative values are converted to use very large bounds.
- Fixed another case of SSS being a bit too bright with nested dielectric.
- Fixed incorrect material rendering if RTX is disabled, nested dielectrics are enabled and you move the camera.
- Fixed incorrect rendering of Vectron geometry.
- Fixed texture projections on SDF objects (Vectron and Volume SDFs).
- Fixed a bug where auto bump map doesn't work as expected when box projection is used.
- Fixed object layer masks of volumes which were messing up custom AOVs.
- Fixed a crash during loading an USD scene that contains curves.
- Fixed random net render hang when no local GPUs are used for rendering.
- Fixed render error when using the baking camera with a baking group ID with empty UV data.
- Fixed issue requiring you to re-login when switching versions of Octane on some Linux distros.
- Fixed issue on Windows causing an ORBX file corruption when updating files on remote drives that have been temporarily disconnected (for example by having the computer go to sleep) - see viewtopic.php?f=9&t=79720 for a discussion of the issue.
- Standalone: Fixed potential crash while loading a new project.
- Standalone: Fixed a crash which happens when triggering an export in the geometry exporter with an invalid path (like an ORBX package) or relative paths. Relative paths are now anchored relative to the project directory if a project exist, otherwise relative to the current working directory.
- Standalone: When we relink the inputs of a scripted graph we take now the order and the type of linker nodes into account to resolve duplicate names.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
WINDOWS ENTERPRISE BUILD (R15-R26)
https://render.otoy.com/customerdownloa ... R4-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R26)
WINDOWS DEMO BUILD (R15-R26)
https://render.otoy.com/plugindownloads ... R4-win.rar
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.117, R26.013). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
