OctaneRender® 2022.1 XB 0
JPeg
I've been testing the new Standard Surface material and I really like it! The option for "Depth" under Transmission is extremely helpful to get some looks I've been unable to create with the Universal Material. However I've also been trying to use it with caustics and the photon kernel, but as soon as the depth is >0 the caustics get disabled, is there plans on supporting the 2 functions at the same time with later releases?
john_otoy
JPeg wrote:I've been testing the new Standard Surface material and I really like it! The option for "Depth" under Transmission is extremely helpful to get some looks I've been unable to create with the Universal Material. However I've also been trying to use it with caustics and the photon kernel, but as soon as the depth is >0 the caustics get disabled, is there plans on supporting the 2 functions at the same time with later releases?
Yes, this will be fixed in a future build.
Kalua
Out of the box:
Same scene has very different looks when opened in OC 2021 and OC 2022. Refer to images.
Regards,
2022 looks terrible, something is going on
2021 looks great
2021 looks great
C4D 2025.1.1 Octane 2025.2.1 v1.5.1, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 552.22
john_otoy
Kalua wrote:Out of the box:
Regards,
Can you PM me the scene so we can take a look at it? Thank you.
Kalua
Regards,
I sent you trough PM.
Rergards,
noldo
Regards,
FBX model I suppose.
Try to toggle "Load vertex normal", is buggy.
renderingz
jobigoud wrote:
rohandalvi wrote:Will support for instance attributes be added in this version?
Instance color maps can be used to store an arbitrary number of instance attributes, in some ways this is superior to having a limited set of attributes built in the instances. Maybe what's needed is more tools to generate and consume these maps.
Could you elaborate on this, specifically in the context of Houdini? The current workflow for using instance attributes in shader is very cumbersome and not at all user friendly.
Win `10/ Cinema 4D R17 / 2 x 780 GTX 6GB + 2 x 980ti
Kalua
Regards,
Thank you, noldo.
But it is a no go. Toggling "load vertex normal" didn't help - same faulty result.
It is an .orbx file.
Regards,
nuno1980
Still no next XB for almost 3 months...
NOTE: I'm sorry for bad english due to mute ;)
i7-12700KF
2x16GB RAM@DDR4-3600
MSI PRO Z690-A DDR4
Zotac GF RTX 4090 <3 :mrgreen:
SSDs OCZ RD400 0.5TB and Crucial 2TB SATA3
HDD 1TB SATA2
LG BD-RE BH16NS40
PSU 1kW
CRT 19" Samtron 19" :|
Despot
nuno1980 wrote:Still no next XB for almost 3 months...
Again it looks like Octane is falling into development hell like it did years ago...
