Per-vertex color data from splines
speltrong
Hi
Is it possible to get per-vertex color data from splines yet? This would particularly be helpful in x-particles where trail splines can change color based on certain criteria that would be very difficult to match with w-coordinate
-s
There's not any attribute that contains color for vertexes of splines. xpTrail is a special object and latest build has support to read this data. See my example for that.
speltrong
Thanks @aoktar!
Good to know that that's data that's specific to the xpTrails object and not the spline itself
-s
speltrong wrote:Thanks @aoktar!
-s
Yes, do you know another method to paint splines?
speltrong
You can change the display color of the spline. Redshift and Arnold can pull that data and you can feed it into the different channels.
speltrong wrote:You can change the display color of the spline. Redshift and Arnold can pull that data and you can feed it into the different channels.
It's not for vertex painting, and using many hair nodes are bottleneck for performance.
speltrong
got it - thanks!
Ofcourse
Hi @aoctar please are you aware of bug while I use a deformer with xpTrail object which has color stored please? With deformer the Octane does not render stored colors
Ofcourse wrote:Hi @aoctar please are you aware of bug while I use a deformer with xpTrail object which has color stored please? With deformer the Octane does not render stored colors
Yes, check my past answers.
Ofcourse
Hello, I have installed recent version of Octane and I have found out that this bug is still in this version, are you aware of this bug being really bad? Let me know please.
