Top View Render for depth maps / height Maps
robin.klein
Hi there,
I don`t find the answer in the Forum. So here is my question:
How can I render a top view of, for example, a mountain in order to get a high quality greyscale depth map / height map?
I want to create 4k-8k highly detailed maps in order to use them later in octane for displacement.
What is the best workflow for that?
I attached a file. I wanttocreate something similar out of Cinema 4d for octane.
Greets
You can use the Z-depth pass, have a look at this old experiment made 10 years ago:
removed wrong link, please continue here: viewtopic.php?f=9&t=76446&p=393450#p393450
Anyway, did you see World Creator?
https://www.world-creator.com/features/
It is available here:
https://render.otoy.com/account/downloa ... LL&ver=ALL
ciao Beppe
pegot
bepeg4d wrote:You can use the Z-depth pass, have a look at this old experiment made 10 years ago:
viewtopic.php?f=78&t=39376&p=183626&hil ... nt#p183626
Hey bepeg4d, the first reference link you provided isn't working for me. For some reason it says "you are not authorized to use this forum," even though I am fully logged in.
Could you provide the steps necessary to create the height map in Octane? I am also wanting to achieve this.
I have been exploring World Creator and while amazing, I see no way to import ones own terrain mesh to generate a height map or use it as a base to start with.
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
Oops, sorry, internal link :oops:
Please look at this example of a displacement map obtained with World Creator, and rendered in c4doctane:
Beauty from World Creator
Than the Z depth pass of the same render:
Z depth pass
Z depth pass
Then the same pass corrected in PhotoShop, by applying a 3D Bump/High filter to invert the Z depth pass, and a an Exposure offset, Gamma correction:
Photoshop color correction
And finally used as displacement map in c4doctane:
final Z depth displacement result
A lot of details are lost, but it is possible to use it in world Creator to bring back the details.
ciao Beppe
pegot
World Creator isn’t an option if you want to create heightmaps from your own geometry (either landscapes or from a hard modeled object). At least I can’t see any option in World Creator to import one’s own mesh.
I was interested in generating heightmaps from objects directly in Octane.
However, Blender offers a very excellent and easy way to do this. . See below URL’s.
https://www.youtube.com/watch?v=arvhK4tvYuY&app=desktop
https://www.youtube.com/watch?v=ekogw2Zm20Y&app=desktop
https://blender.stackexchange.com/quest ... -from-mesh
https://www.youtube.com/watch?v=F77qiuJ ... e=youtu.be
The exported heightmaps work perfectly in Octane. But Is there any equivalent way in Octane to do what these Blender techniques can? Just wondering.
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
You can do something similar by using the Falloff node in 90° mode, but I prefer to use a top Orthographic Camera, in Z pass mode, the use the 3D/Bump-High filter in Photoshop, to have a rough Highmap to be used in World Creator:
c4d viewport
c4d viewport
Top Z-Depth pass
Top Z-Depth pass
after Photoshop filter
higmap imported in World Creator
to add some filters
to add some filters
ciao Beppe
itsallgoode9
bepeg4d wrote:You can do something similar by using the Falloff node in 90° mode, but I prefer to use a top Orthographic Camera, in Z pass mode, the use the 3D/Bump-High filter in Photoshop, to have a rough Highmap to be used in World Creator:
ciao Beppe
Is there some weird reason why, in octane, you can't just set a min/max distance for z-depth, so you get a full range of black to white in the render? Seems pretty standard to be able to do that?
