C4D crashing without warning after sending render to PV
FH wrote:
aoktar wrote:give a try and also use 2020.1-R6
Ok will do. Can you show me where that command is ?
FH
I'm still getting crashes after emptying cache and installing 2020.1 r6.
octanelog_report.zip
(546.25 KiB) Downloaded 154 times
FH
Crashes happen even when juste sending to LV, and always occur during materials loading.
FH
[2020-06-01 16:02:21][1] generate material:M_1asd0f1a6s0d16w016[2020-06-01 16:02:22][1] OCT:the following error occurred while reading a binary blob: failed load data array
This showed in the last crash.
FH wrote:[2020-06-01 16:02:21][1] generate material:M_1asd0f1a6s0d16w016[2020-06-01 16:02:22][1] OCT:the following error occurred while reading a binary blob: failed load data array
The command I pointed that should solve this issue. Other than this delete prefs folder of c4d and try again.
FH
I've tried all of the above, but while looking at the octane log, I found this :
[2020-06-02 12:51:47][0] Scene created in plugin version 4050001
[2020-06-02 12:51:47][0] Scene plugin version is older than version:2020.1-R6
Should I copy all my scene and paste it in a new template ?
jayroth2020
@FH, please attach a scene that causes your issue to occur so we can take a look at it.
FH
jayroth2020 wrote:@FH, please attach a scene that causes your issue to occur so we can take a look at it.
Here. I can't open the scene now, would crash right away.
jayroth2020
Thanks, did you say that this file was originally created in v4?
FH
Yes, it was because I created a template for C4D when I was running on v4.
I removed my template, create a new scene, and copy paste the scene in the blank new scene so it'll fix that problem.
I have opened a previous version for my scene, before everything went crazy crashing. I also de an reinstalled octane plugins and standalone. I haven't encountered any issue for now.
