FH wrote:Ok will do. Can you show me where that command is ?aoktar wrote:give a try and also use 2020.1-R6
C4D crashing without warning after sending render to PV
I'm still getting crashes after emptying cache and installing 2020.1 r6.
- octanelog_report.zip
- (546.25 KiB) Downloaded 147 times
The command I pointed that should solve this issue. Other than this delete prefs folder of c4d and try again.FH wrote:[2020-06-01 16:02:21][1] generate material:M_1asd0f1a6s0d16w016[2020-06-01 16:02:22][1] OCT:the following error occurred while reading a binary blob: failed load data array
This showed in the last crash.
I've tried all of the above, but while looking at the octane log, I found this :
[2020-06-02 12:51:47][0] Scene created in plugin version 4050001
[2020-06-02 12:51:47][0] Scene plugin version is older than version:2020.1-R6
Should I copy all my scene and paste it in a new template ?
- jayroth2020
@FH, please attach a scene that causes your issue to occur so we can take a look at it.
- jayroth2020
Thanks, did you say that this file was originally created in v4?
Yes, it was because I created a template for C4D when I was running on v4.
I removed my template, create a new scene, and copy paste the scene in the blank new scene so it'll fix that problem.
I have opened a previous version for my scene, before everything went crazy crashing. I also de an reinstalled octane plugins and standalone. I haven't encountered any issue for now.
