For a few weeks now Cinema4D is crashing without warning when render is send to PV.
I'm using C4D R20.059, with Octane 2020.1, as well as a slave computer with the same Octane version.
Windows is up to date on both machines and Nvidia drivers too : 442.92
Sometimes the rendering would go through without problems, but every 3 or 4 render sent, C4D would crash.
Is anyone experiencing the same issue recently ? Is it because I am using 8k hdri or millions poly objects (only one in my scene tho) ?
Config :
i9 9900k
64Gb DDR4
RTX 2080ti + Slave node 2x1080ti
Please find attached the last bugreport file.
C4D crashing without warning after sending render to PV
- Attachments
- _BugReport.txt
- (552.33 KiB) Downloaded 187 times
While rendering which scene?
Thanks, here are the logs.
I was just doing some adjustments, sending the scene to PV, having the render going on, and then another PV and it crashed.
- Attachments
- octanelog_report.zip
- (535.61 KiB) Downloaded 206 times
Have you ever try to use "Empty texCache" command?
give a try and also use 2020.1-R6
