C4D crashing without warning after sending render to PV
FH
For a few weeks now Cinema4D is crashing without warning when render is send to PV.
I'm using C4D R20.059, with Octane 2020.1, as well as a slave computer with the same Octane version.
Windows is up to date on both machines and Nvidia drivers too : 442.92
Sometimes the rendering would go through without problems, but every 3 or 4 render sent, C4D would crash.
Is anyone experiencing the same issue recently ? Is it because I am using 8k hdri or millions poly objects (only one in my scene tho) ?
Config :
i9 9900k
64Gb DDR4
RTX 2080ti + Slave node 2x1080ti
Please find attached the last bugreport file.
_BugReport.txt
(552.33 KiB) Downloaded 179 times
While rendering which scene?
FH
aoktar wrote:While rendering which scene?
Pretty much any scene... From 9Mb files to 150Mb+ files, there is no specific scene where this issue is happening.
FH
Could it be because my output resolution is 5k+ ?
ok please apply the instructions
FH
Thanks, here are the logs.
I was just doing some adjustments, sending the scene to PV, having the render going on, and then another PV and it crashed.
octanelog_report.zip
(535.61 KiB) Downloaded 189 times
Have you ever try to use "Empty texCache" command?
FH
aoktar wrote:Have you ever try to use "Empty texCache" command?
No I haven't. Where can I find this option ?
give a try and also use 2020.1-R6
FH
aoktar wrote:give a try and also use 2020.1-R6
Ok will do. Can you show me where that command is ?
