Cinema 4D version 2019.1.4-R2(Obsolete stable) 07.12.2019
Is it possible in this version to color the vdbs with textures? And if yes, how do we do that? thanks
+1thanulee wrote:Testing it atm. Small detail: when i save from LV the demain pass as "png tonemapped" the gamma is wrong.
Thanks!!
In my experience this issue has been there since always.divasoft wrote:+1thanulee wrote:Testing it atm. Small detail: when i save from LV the demain pass as "png tonemapped" the gamma is wrong.
Thanks!!
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
Yes. I did not say anything about this because Ahmet’s usual answer to this is that I’m busy with more important things.Kalua wrote:In my experience this issue has been there since always.divasoft wrote:+1thanulee wrote:Testing it atm. Small detail: when i save from LV the demain pass as "png tonemapped" the gamma is wrong.
Thanks!!
Maybe I'm blind, how do you get it? It seems fine to methanulee wrote:Testing it atm. Small detail: when i save from LV the demain pass as "png tonemapped" the gamma is wrong.
Thanks!!
Here is an example: saving tonnemapped png from denoised pass.aoktar wrote:Maybe I'm blind, how do you get it? It seems fine to methanulee wrote:Testing it atm. Small detail: when i save from LV the demain pass as "png tonemapped" the gamma is wrong.
Thanks!!
if we save demain pass as "png tonemapped" we get image with linear color space instead sRGB.aoktar wrote:Maybe I'm blind, how do you get it? It seems fine to methanulee wrote:Testing it atm. Small detail: when i save from LV the demain pass as "png tonemapped" the gamma is wrong.
Thanks!!
In LV the pictures look the same, but if you open both in Photoshop, you will see that they look like different gamma. We need sRGB color space for all tonemapped passes.
Why is it when I save my c4d scene with the live viewer open it takes about x5 longer than when the live viewer is closed. I noticed in the bottom left when the live viewer is open and I AM saving, it runs a bunch of stuff that goes really fast, and when its closed it doesn't do that. Has only started happening with the last 2 2019 versions.... anyone else? I have autosave setup for every 5 minutes and its getting annoying, especially with larger cad scenes. But if I don't have autosave setup, c4d and octane is so unstable I crash like 10 times a day and lose hours of work....
Actually it only happens when it is rendering with the liveviewer open, not just when its opened paused.
Win 10, Threadripper Pro, Dual 3090s
It's not unstable if you don't use Game Ready drivers. Also I didn't see a behavior like that. Probably you have interesting case. Please send me your scene for testing.LFedit wrote:Why is it when I save my c4d scene with the live viewer open it takes about x5 longer than when the live viewer is closed. I noticed in the bottom left when the live viewer is open and I AM saving, it runs a bunch of stuff that goes really fast, and when its closed it doesn't do that. Has only started happening with the last 2 2019 versions.... anyone else? I have autosave setup for every 5 minutes and its getting annoying, especially with larger cad scenes. But if I don't have autosave setup, c4d and octane is so unstable I crash like 10 times a day and lose hours of work....
Keep in mind that not cards are supported by the Studio Drivers.It's not unstable if you don't use Game Ready drivers.
My Titan X Maxwell cards can only utilize the Game Ready Drivers.
i7 4930K_Asus_RampageIV-Extreme_64GB_3-Titan_NVIDIA-337.88_Win7-64
