Cinema 4D version 2019.1.4-R2(Obsolete stable) 07.12.2019
thanulee
Is it possible in this version to color the vdbs with textures? And if yes, how do we do that? thanks
divasoft
thanulee wrote:Testing it atm. Small detail: when i save from LV the demain pass as "png tonemapped" the gamma is wrong.
Thanks!!
+1
Kalua
Thanks!!
+1
In my experience this issue has been there since always.
C4D 2025.1.1 v1.8.4 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 560.94
Octane User since V1 Beta
divasoft
Kalua wrote:
Thanks!!
+1
Yes. I did not say anything about this because Ahmet’s usual answer to this is that I’m busy with more important things.
Thanks!!
Maybe I'm blind, how do you get it? It seems fine to me
Kalua
Thanks!!
Here is an example: saving tonnemapped png from denoised pass.
divasoft
Thanks!!
if we save demain pass as "png tonemapped" we get image with linear color space instead sRGB.
In LV the pictures look the same, but if you open both in Photoshop, you will see that they look like different gamma. We need sRGB color space for all tonemapped passes.
LFedit
Why is it when I save my c4d scene with the live viewer open it takes about x5 longer than when the live viewer is closed. I noticed in the bottom left when the live viewer is open and I AM saving, it runs a bunch of stuff that goes really fast, and when its closed it doesn't do that. Has only started happening with the last 2 2019 versions.... anyone else? I have autosave setup for every 5 minutes and its getting annoying, especially with larger cad scenes. But if I don't have autosave setup, c4d and octane is so unstable I crash like 10 times a day and lose hours of work....
Actually it only happens when it is rendering with the liveviewer open, not just when its opened paused.
Win 10, Threadripper Pro, Dual 3090s
LFedit wrote:Why is it when I save my c4d scene with the live viewer open it takes about x5 longer than when the live viewer is closed. I noticed in the bottom left when the live viewer is open and I AM saving, it runs a bunch of stuff that goes really fast, and when its closed it doesn't do that. Has only started happening with the last 2 2019 versions.... anyone else? I have autosave setup for every 5 minutes and its getting annoying, especially with larger cad scenes. But if I don't have autosave setup, c4d and octane is so unstable I crash like 10 times a day and lose hours of work....
It's not unstable if you don't use Game Ready drivers. Also I didn't see a behavior like that. Probably you have interesting case. Please send me your scene for testing.
artdude12
Keep in mind that not cards are supported by the Studio Drivers.
My Titan X Maxwell cards can only utilize the Game Ready Drivers.
i7 4930K_Asus_RampageIV-Extreme_64GB_3-Titan_NVIDIA-337.88_Win7-64
Return to “Releases”
