OctaneRender™ 4 RC 7
abstrax
Hi all,
This is another release candidate fixing various issues in the materials as well as the material preview rendering. We really hope that this is the last one and we can get the stable version out next week.
As mentioned in the previous release, we are still looking at various stability issues, especially one issue that was reported by various users where Octane rendering fails with spurious CUDA error 2 (out of memory). It seems to happen at specific points during the scene initialization phase but during CUDA calls that don't allocate any memory. For the one scenario where we could reproduce the issue, we have found a workaround to "fix" it, but since it might be just some obscure side-effect of some other problem, it might pop up again in some other scenario. I.e. we need more data from users and more failure cases and any help by you is very much appreciated.
Please note that this build will expire in 120 days, this is now shown on the bottom right of the Standalone release.
As before, some introductory material on V4 can be found here: first release post of V4.
Please make sure you have NVIDIA driver 387 or newer on Windows and Linux, and any CUDA driver for Mac that supports CUDA 9.1. Please also note that architecture improvements mean we can no longer support Fermi GPUs.
Changes since OctaneRender 4 RC 6:
  • Added option to the batch render script and job to allow saving of both the main and the denoised main passes (see viewtopic.php?p=348116#p348116).
  • Fixed broken preview rendering if the main render module hasn't been initialized yet (see for example here: viewtopic.php?p=348636#p348636).
  • Fixed darkening of the planar material preview rendering when a glossy, meetal or universal material is being rendered.
  • Fixed artifacts in the sheen / coating layers of the universal material (see viewtopic.php?p=347984#p347984).
  • Fixed fireflies when sheen and coating are both enabled in the universal material.
  • Fixed clear coat of universal material to have no effect if its IOR is 1.
  • Fixed energy gain at glancing angles when the clear coat roughness is low.
  • Fixed excessive usage of system memory during the compilation of heavily overlapping geometry.
  • OSL: Added support for specifying a step size for integer inputs via the sensitivity metadata.
  • Standalone: Fixed incorrect progress bar updates on Windows 10.
  • Standalone: Reimplemented rotation handle which now allows you to rotate objects multiple times around the picked axis.
  • Lua: Added octane.project.setSelection() which clears the current selection and selects the given node items and pins.
Downloads for users with a regular license
OctaneRender for Windows (installer)
OctaneRender for Windows (zip)
OctaneRender for Mac OS
OctaneRender for Linux
Downloads for users with a Studio subscription license
Happy rendering,
Your OTOY Team
KeeWe
Thx for the update: I've a question about the new licensing system: As far as I know we will be able to use GPUs in our network as soon as V4 is stable without getting another license (as holder of a perpetual license). Is this correct? And if so: will this new licensing system go online the day you release a stable v4?
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
grimm
I have noticed that error when I'm also running another program that makes very heavy use of the GPU. In my case it was when I was running 3D-Coat along with Octane, they do not work well with each other. :)
funk
Thanks OTOY
glimpse
"I've found reducing parallel samples and max tile samples seems to help reduce instances of Octane crashing. I get the CUDA 700 error with heavy scenes when editing shaders. Happening a lot less often with 8/16 for those settings rather than the default. (C4D btw). " source: from comment in https://www.facebook.com/groups/OctaneR ... 940645516/
coilbook
one of my slaves (3gpus + 4 gpus in netstor box, 1080s and titans xps) constantly has an error "out of memory". Even when I enable out of core. All other slaves work fine. Motherboard is ASUS ROG Rampage VI Extreme LGA2066 DDR4 M.2 U.2 X299 EATX Motherboard with onboard 802.11AD WiGig Wi-Fi USB 3.1, 32 gb of ram, i9-7900x abd nvme for 250GB only. Windows 10 PRO
It happens a lot after octane viewport is used and then rendering begins. I really think it has something to do with ASUS boards too, PLX chips, etc. This is the same PC that would just freeze without any errors. Complete freeze. This is the only slave that has 7 GPUs others have 5, 3 and 3
Four slaves are connected to the netgear 10 Gbit switch. And this is the only slave out of 4 messing up. Other slaves have the same video cards 1080s, titans and one more netstor box. This is the only slave with built in 10 Gigabit port. Others have intel 10 Gigabit network cards installed
linvanchene
Nishita Daylight Model
I do not see any effect when adjusting the Sky Turbidity parameter.
Update / Edit:
Not seeing an effect when adjusting Sky Color and Sunset Color as well in the Nishita Daylight Model.
Any other parameter that needs to be adjusted in combination?
Or are those parameters simply not used in the Nishita Daylight Model?
In the New Daylight environment adjusting Sky Turbidity alone shows a huge difference in shadow softness as expected. Sky and Sunset Colors also change drastically as expected.
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
wallace
linvanchene wrote:Nishita Daylight Model
Update / Edit:
Nishita Sky does not work with sky color and sunset color given that it is a physically based model. Turbidity however should work, I'll look into it.
profbetis
The Universal Material has a strange behavior at low specular roughness values. It has these harmonic ring looking artifacts. These artifacts fade away as roughness approaches 0.002 and up.
I tested the same on the metallic material and no such artifacts exist.
Ray Epsilon has no affect.
The rings shift around when the metallic parameter is adjusted, in my case around the values 0.9 to 1.0
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
coilbook
Can anyone at otoy explain to me when to use AI lights and Ai light update? When I have a lot of lights. I dont see any difference using it or not. Denoiser works the same and noise levels are the same
UPDATE:
I tried a scene with a lot of lights and yes there is a big difference when using AI light but there is a possible bug I posted in max forum when ai lights work in octane viewport and not during rendering viewtopic.php?f=80&t=69152&start=70
