4.0 XB4 - 16.2 – Material Library VX non functional
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
J.C
Hi, it's te same as in 15.x.x. Adding new library item does not do anything. Works as expected in official Blender builds.
System – Windows 11
AndreasResch
You can also try Asset Management for Blender. I use it for a long time and it works with Octane too.
https://gumroad.com/l/asset_management
Cheerio,
Andreas
J.C
Thanks for the info Andreas!
System – Windows 11
J.C
On 16.2.4 this is still not functional. Adding new library results in nothing.
System – Windows 11
DrawFun
Hi J.C,
Thanks for your report. Could you please tell me which way do you use to install OctaneBlender on Mac? Archive or PKG? Thanks.
Cheers,
DrawFun
J.C
I used Archive to install OctaneBlender.
System – Windows 11
DrawFun
Hi J.C,
Could you please try to run blender from the terminal and test it again? Thanks.
cd $BLENDER_FOLDER
./blender.app/Contents/MacOS/blender
Cheers
DrawFun
J.C
Hi DrawFun,
after launching Blender from terminal adding libraries work. Still this is kind of buggy addon. Removing material does not work, but adding does.
System – Windows 11
DrawFun
Hi J.C,
Thanks for your tests. Add/remove works for me. Could you please try to refresh the libs?
PS: To get rid of typing commands every time, you can put the code in a shell script under the blender folder. Then run blender from the script instead of the blender.app as workarounds.
#!/bin/sh
echo "Start blender from terminal..."
DIR=$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )
cd "${DIR}"
Cheers,
DrawFun
Return to “Bug Reports”
