4.0 XB4 - 16.2 – Material Library VX non functional
C. RAM Capacity (i.e. 6 GB)
Hi, it's te same as in 15.x.x. Adding new library item does not do anything. Works as expected in official Blender builds.
System – Windows 11
System – Windows 11
- AndreasResch
You can also try Asset Management for Blender. I use it for a long time and it works with Octane too.
https://gumroad.com/l/asset_management
Cheerio,
Andreas
Cheerio,
Andreas
Thanks for the info Andreas!
System – Windows 11
System – Windows 11
On 16.2.4 this is still not functional. Adding new library results in nothing.
System – Windows 11
System – Windows 11
I used Archive to install OctaneBlender.
System – Windows 11
System – Windows 11
Hi J.C,
Could you please try to run blender from the terminal and test it again? Thanks.
Cheers
DrawFun
cd $BLENDER_FOLDER
./blender.app/Contents/MacOS/blenderDrawFun
Hi DrawFun,
after launching Blender from terminal adding libraries work. Still this is kind of buggy addon. Removing material does not work, but adding does.
System – Windows 11
System – Windows 11
Hi J.C,
Thanks for your tests. Add/remove works for me. Could you please try to refresh the libs?
PS: To get rid of typing commands every time, you can put the code in a shell script under the blender folder. Then run blender from the script instead of the blender.app as workarounds.
Cheers,
DrawFun
#!/bin/sh
echo "Start blender from terminal..."
DIR=$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )
cd "${DIR}"
DrawFun
- image.png (23.32 KiB) Viewed 3261 times
