OctaneRender™ 4 RC 4
Notiusweb
Zay wrote:
Notiusweb wrote:Not sure if this is a bug. If it is, it has been going on since all versions I have tried (3.02 and >).
But just looking for some thoughts as I am seeing this in RC4...
Try the "Welding" setting when importing the abc file.
Hi Zay, thank you for the suggestion.
I did try it, but it does not resolve it.
I am thinking you mean the checkbox for 'Merge Unwelded Vertices', right?
*(You don't have to answer, but please do if you meant something else. Thx!)
Otoy team - maybe these settings are not working when Subdivision is > 0? (1, 2, 3, etc)
In my case checking 'Load Vertex Normals' only resolves a UV issue when SubD is 0.
Thx
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Zay
Region Render is slowed down a lot by the "Max. tonemap interval" settings. At "1" region render update fast - at "20" it is very very slow.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
vijay
grimm wrote:Hi Guys,
Thanks for the new version, but it's not running on my Linux Mint 19 system. I downloaded it and ran, the window popped up for downloading the cudnn library. It downloaded ok, at least no errors, but then it just sat there with the splash window and didn't open the main Octane window. I checked my system monitor and saw that one CPU core is pegged at 100%. I let it run for a few minutes with no change, and then I killed it.
I restarted Octane and it didn't open the cudnn download window, but it's still stuck at the splash window and the main interface never opens. During this time one of the CPU cores is again pegged at 100% usage. I ran it from the terminal but no error messages are displayed. I had to kill it again after several minutes of running.
Jason
Sent you a pm.
vijay
Thx
Vertex normals from the file are useless when a subdivision is applied on a mesh, so we will have to calculate it on runtime. I guess the problem is the winding order of the body and hands are not same, you can confirm it by rendering the character in the wireframe info channel kernel with wireframe backface highlighting enabled.
vijay
funk wrote:I'm just messing around with a scene where the denoiser is running every 20 seconds or so.
I noticed the result looks quite clean, but has random dots in several areas. It's a bit too big to attach to the forums.
(EDIT: I PMed a dropbox link to haze. Let me know if I should send it somewhere else)
Here is what it looks like (ctrl+zoomed in to make it easier to see). It looks the same even after rendering for 20 minutes
Alwyn is not in the office today, so could you please send me the link as well?.
Notiusweb
Hi-
Just to give all, both of these scenarios have the issue when checkbox for 'Load Vertex Normals' is off:
SubD off
SubD on
Is there a way I can make Octane calculate Vertex Normals at runtime, I wasn't sure if it is a setting somewhere?
THX!
Plugs: Enterprise
Kalua
Have you tried playing with caustics blur? Seems to me AI denoiser works better with lower values.
This build looks great so far. No bigger issues than a bit of lagging after replacing textures or editing some properties. Other than that it feels stable to me.
Octane User since V1 Beta
abstrax
Hi-
SubD off
ABCSubD_Off.2.png[/[attachment=2]WireFrame_NoSubD.jpg
SubD on
THX!
If you disable loading of vertex normals, they are calculated during runtime. It definitely looks like the mesh consists of multiple unwelded patches. Could you please send us the scene so we can investigate? Thank you.
nuno1980
@abstrax
Please read my message on Fri Sep 14, 2018 9:06 am UTC. It's ALERT! because my current GTX 980 Ti will be died in maybe this year and later I will buy new GeForce RTX 2080 Ti but I will get without Octane v2 for no new RTX support. Therefore, I'm much worried!!
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
abstrax
Hi-
SubD off
SubD on
THX!
I had a look at the scene you sent to me and the problem is that the body mesh is split into separate mesh objects. Currently there is no way to "fuse" them back to one mesh in Octane. Since the subdivision is done on a per-mesh basis, the subdivided meshes will be discontinuous which becomes very obvious when looking at the sub-divided normals.
This means that the only way to solve the problem is to export the geometry as one mesh object.
In case you are interested: When you load an Alembic or FBX file, the created nodes are contained in a geometry archive, which is just a "fancy" node graph. By default Octane doesn't allow inspecting these node graphs, because they can contain tens of thousands of nodes or people might start deleting nodes and changing connections, etc., which would break the geometry. But you can tell Octane to allow you inspecting geometry archives by enabling the log flag makeAllInspectable. I.e. create a log flags file octane_log_flags.txt in the same directory where the Octane Standalone binary can be found and write makeAllInspectable into it. After restarting Octane you will be able to inspect loaded Alembic or FBX geometry archives. This might make it a bit more clear what is happening with this scene.
