Emitters
Pavlov
im' trying a scene exported with LW, it's all ok but emitters dont work.
I had a separate layer with emitter geometry, once exported i pick the material and i try all eitter types, but dont see any result even if i raise power to the top.
what can i miss ?
thank,
Paolo
I7 960 3.2 GHZ - 6GB ram - GTS 250 display only - Asus GTX 470
Pavlov
ciao beppe,
nope... sadly it's ok ;(
no switch to turn on somewhere ? no oddities around this feature ?
Emitters are small discs on the roof of a room, could this affect the time to see some light in the scene (i left it run for 4 min on a gtx470) ?
Paolo
Pavlov
ok, here's the scene.
LAMP material should emit light, can someone tell me what's wrong here?
Importing the OBJ into Lw all normals are flipped but i assume it's a LW issue, since all other materials render correctly into octane.
thanks,
Paolo
test.rar
(1.66 MiB) Downloaded 157 times
Pavlov
PS - i opened obj onto LW, i flipped emitters normal, exported obj again, but still doesnt work.
Paolo
Henrik
Tried with two of your lights, I have the same problem.
the only way to get the emitter to light is to let the normal pointing inward
cheers
Asus p67|Windows 10|GTX970_GTX1070|i7-2600K|16GBRAM
| FormZ|C4D
Pavlov
hi,
normals were facing inwards before i flipped them, but even that way emitters didnt work.
Tweaking parameters i managed to get emitter bright (they were visible) but they didnt cast light.
If they cast any light, it must be extremely slow to show because it's not there after 4 min on a GTX 470.
How long simplified scene above took to render ? Did you see lighting immediately or did it show after some minutes of refining ?
thank,
Paolo
Henrik
immediately,it was a 2 sec render
| FormZ|C4D
PhilBo
Did you have it on Path Tracing or Direct Lighting?
Win7 64| Two GTX 470s | Phenom II 920 | 8 GB
Win7 32| GTX 260 | Athlon X2 5000+ BE | 2 GB
Henrik
Direct Lighting
| FormZ|C4D
