Smooth & Easy Camera Animation for OR Standalone, ORC v1.21
thefishnut
Is it possible to have a texture animation occurring simultaneously with the animated camera using Ready Cam?
I can't seem to find a way to have both occur at once.
Many Thanks,
Chris.
Win 8 64 | 2 x Geforce GTX780 6gb | i7 4790k | 32GB
whersmy
I still get the paused render bug where it only renders out 1 frame after increasing the s/px, is there a fix for this? I`m on 3.07 using the 1.21V
In the preview it renders out perfectly..
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
whersmy
Does anyone get this working on older versions if Octane? :?:
whersmy
Small bump. Getting this working correctly makes Octane so much more productive in combination with ORC and adaptive sampling.
And really not looking forward reverting back to Keyshot for this..!
whersmy
No takers on this? I am sure I am not the only one looking forward on getting this working :!:
roeland
Do you have any output in the log window?
I think what you have to fix is the end of function Render.callback(rc) in the file render.lua .
    local h = math.floor(et/3600)
    local m = math.floor((et-h*3600)/60)
    -- add math.floor():
    local s = math.floor(et-h*3600-m*60)
    -- Change the first placeholder to %.1f:
    progress.frame.bar:updateProperties {
        progress=pc, text=string.format("%.1f% - %02d:%02d:%02d",100*pc,h,m,s)
domusbiro
I'm having an error when pressing alt+a . Anyone had this problem ?
whersmy
roeland wrote:Hi,
I updated the file render.lua, but it seems there is no change. It only renders and saves the first frame, and that`s it. No promts as well.
Also it outputs this log after updating the end of function Render.callback(rc) in the file render.lua .:
Error raised in callback:
C:\Users\Desktop\MK\Orc_bin/render.lua:444: bad argument #7 to 'format' (number has no integer representation)
stack traceback:
	[C]: in function 'string.format'
	C:\Users\Desktop\MK\Orc_bin/render.lua:444: in method 'start'
	...ers\Desktop\MK\Orc_bin/Tab/animate.lua:438: in function <...ers\Desktop\MK\Orc_bin/Tab/animate.lua:412>
	[C]: in method 'showWindow'
	[string "Ol Ready Cam.lua"]:107: in main chunk
domusbiro
Did you try unchecking the Force sequential numbering?
roeland
This is the version I currently have, that should have all the fixes above applied.
Ol Ready Cam.zip
(50.36 KiB) Downloaded 507 times
Return to “Lua Scripting”
